Mystery transmission part found in pan. Help!
Old 03-25-2016, 08:17 PM
JimG4652's Avatar
JimG4652
JimG4652 is offline
Question Mystery transmission part found in pan. Help!
I pulled my transmission pan to find this little guy sitting in the bottom of it. I've gone over parts lists and exploded views of the 46re trans but can't for the life of me find out what it is or where it goes.
Can anyone help? Thanks in advance.
Attached Thumbnails Mystery transmission part found in pan. Help!-img_20160325_191219518.jpg
Old 03-25-2016, 08:57 PM
bjr1a's Avatar
bjr1a
bjr1a is offline
This is a front band strut......No second gear correct?.......
Old 03-25-2016, 09:05 PM
JimG4652's Avatar
JimG4652
JimG4652 is offline
It was shifting through all the gears, but I'd have to go WOT to 5k in first, then let off the gas to get it to shift into 2nd. All the other shifts were fine, but it the converter would unlock every so often while cruising. So I replaced all the sensors today; but found that in the pan when I dropped it. Thanks for ID'ing it for me.
Old 03-25-2016, 09:07 PM
JimG4652's Avatar
JimG4652
JimG4652 is offline
I have to add the 1-2 shift issue was intermittent. It would Rev to 3k light throttle and shift into 2nd sometimes, but when the fluid got hot I'd have to floor it to get it to shift. I also adjusted the TV cable until I was blue in the face.
Old 03-25-2016, 09:09 PM
bjr1a's Avatar
bjr1a
bjr1a is offline
Its actually skipping 2nd gear....it can be reinstalled but requires valve body removal....I have seen this many times and about half the time no other damaged occurs...apparently the band stretches and allows the strut to fall out of place.....
Old 03-25-2016, 09:22 PM
JimG4652's Avatar
JimG4652
JimG4652 is offline
The valve body is already out for the sensors/solenoids/ line pressure sensor. Went ahead and ordered a billet accumulator piston while it was apart, so it'll be a few days. I'll put the anchor back in while I'm waiting for the piston to arrive. Thanks again, I had a mini heart attack for a little while.
Old 03-26-2016, 12:11 AM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Just an FYI...
Would the place where that part goes be noticeable when you dropped the valve body or would you just have to "know" where it goes?
Old 03-26-2016, 08:04 AM
JimG4652's Avatar
JimG4652
JimG4652 is offline
I was able to Google it once I found out what it was. Seems easy enough to put it back in, but I'll find out when I cross that bridge.
Attached Thumbnails Mystery transmission part found in pan. Help!-screenshot_2016-03-26-07-00-12.png
Old 03-26-2016, 08:10 AM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Thanks. Just pocketing that info for future reference.
Old 03-26-2016, 11:04 AM
Moparite's Avatar
Moparite
Moparite is offline
Usually see these broken in the pan.
Quick Reply: Mystery transmission part found in pan. Help!
