Lost Factory Tune
Old Mar 29, 2016 | 10:09 AM
"Performance" comes from the tune. The old Mopar Performance PCM was for the OBDI fellers, that you couldn't flash program. With the advent of OBDII, no longer necessary to replace the PCM, just update the programming.
Old Mar 29, 2016 | 10:19 AM
dean98ram1500's Avatar
dean98ram1500
Oh, makes sense. I gotcha. If I could find a secondary PCM just as a back up, that would be great.
Old Mar 29, 2016 | 10:23 AM
Check your local junkyards.
Old Mar 29, 2016 | 02:26 PM
dean98ram1500
But then aren't those programmed with Vin's?
Old Mar 29, 2016 | 06:36 PM
It will still run the engine/trans, just no ABS, or I think.... Airbags.
Old Mar 29, 2016 | 06:38 PM
dean98ram1500
Hmm.. I can do without ABS, but Airbags might be nice lol.
I wonder if an electronics shop would be able to transfer my stock tuning from the one tuner to the other since SCT is out of the question.
Old Mar 29, 2016 | 06:48 PM
Do the tuners have USB ports?
Old Mar 29, 2016 | 06:49 PM
dean98ram1500
They both have a port where I have a special wire that goes from the tuner into a computer via USB is that is what you mean.
Old Mar 29, 2016 | 06:52 PM
USB to OBDII? what flavor USB port?
Old Mar 29, 2016 | 06:54 PM
dean98ram1500
There's a wire coming out of the tuner that goes to OBDII, then there is another port in the bottom where I hook a printer cable into, and on the other end it goes to a USB port, and as in flavor do you mean USB 2.0?
