Help with reading the "Check Engine Light" Code.
Old Apr 30, 2016 | 01:09 PM
bosanci28's Avatar
bosanci28
Default Help with reading the "Check Engine Light" Code.
I have the 1995 Dodge Ram 1500 5.2L, and the check engine light comes on and off, and i know there is a code and can't figure out the the numbers are.
So here is the video , if someone can help me with the and how many times it flashes and what is the exact error code.
Video:
You will see that i turn the key 2 times on/off and the 3rd time i leave it on, then the really check engine light code starts to flash.
Thanks for any help.
Old Apr 30, 2016 | 01:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Piece of cake. 12 battery disconnect 41GENERATOR FIELD NOT SWITCHING PROPERLY and 55 end of test. And do you know Matt Kelly the lives in rocklin?
Old Apr 30, 2016 | 01:33 PM
master tech
1st flash is one long flash and the two quick flashes is 2. The next one was 4 long flashes and then 1 quick flash is 1 code 41. next one was 5 long flashes and then 5 quick flashes 5 code 55 end of test.
Old Apr 30, 2016 | 01:34 PM
bosanci28's Avatar
bosanci28
Hello, Thanks for that info.
I did have a ABS light on due to brake problem, had air in the system and now is fixed , and i think for sure i have disconnected the battery for 30-1 hour and maybe that's why i guess i get the check engine light off and on.
Abs/brake bleeding problem was fixed about 3 weeks ago, and the check engine light started
to come a week later.
Sorry, i do not know Matt.
Thanks again for that fast reply and help!
bosanci28's Avatar
bosanci28
12 and 41.
Thanks.
Old Apr 30, 2016 | 02:40 PM
BigGreenRam's Avatar
BigGreenRam
What did u do to get the air out of the system I've bled my like crazy still have abs/ brake light on I had a wheel cylinder go bad and bout lost all fluid I think the air still got in the abs
Old Apr 30, 2016 | 05:29 PM
bosanci28's Avatar
bosanci28
I had bleed it first time , had someone in the cab pressing the brake pedal 4-5 times and hold , and me at the wheel i release the small bleeder valve and i come out normal, or very little air. So i did it to all 4 wheels because, if you have a problem to one wheel you still need to bleed them all.
And everything was fine but after few days up to a week my pedal was going to worse , had to press 3-5 times to get some good brake and the abs light come on!
So i decided to bleed them again, and o may god this it was a lot of air build up in the system, but from where not sure. And now is been few weeks and have no abs light and brakes are ok.
I think you still have air in the system.
This here :
Amazon.com: Phoenix Systems (2005-B) Bench Brake Bleeder Kit, One Person Bleeder, Fits All Makes and Models: Automotive Amazon.com: Phoenix Systems (2005-B) Bench Brake Bleeder Kit, One Person Bleeder, Fits All Makes and Models: Automotive
or
Amazon.com: Phoenix Systems (2104-B) V-5 Reverse Brake Bleeder, Light Duty One Person, Fits all makes and models: Automotive Amazon.com: Phoenix Systems (2104-B) V-5 Reverse Brake Bleeder, Light Duty One Person, Fits all makes and models: Automotive
I may buy for my self next , it pushes air out under the hood, reverse engineering .
Old Apr 30, 2016 | 05:49 PM
I would suspect a leak in the system somewhere.......
Old Apr 30, 2016 | 07:14 PM
master tech
Don't worry about code 12, That just means the battery had been disconnected. It will clear after 255 key cycles or with a scanner. But the check engine light would not be on for code 12.
