2000 Durango 5.2l engine into 01 ram
Old May 27, 2016 | 06:27 PM
angrysmileyface's Avatar
angrysmileyface
Default 2000 Durango 5.2l engine into 01 ram
Is this feasible or am I just wasting my time
Old May 27, 2016 | 07:15 PM
If your ram originally had a 5.2 engine, it'll drop right in, and bolt right up. Hook up the electrical, drive it away.
Old May 27, 2016 | 07:38 PM
angrysmileyface
Great. Friend has an 01 with a theoretical locked engine. This is the quickest route shy of buying a new vehicle
Old May 27, 2016 | 07:43 PM
Think I would do a bit o' troubleshooting before throwing a motor at it.
Old May 27, 2016 | 10:28 PM
angrysmileyface
If it were my own car I'd say yes, but I'm more afraid he ran the car out oil since apparently it made some horrible noises the same day he did an oil change. Plus I really don't want to get into a total teardown since the really need the truck asap
Old May 27, 2016 | 10:40 PM
Just put a ratchet on the crank, and see if it'll turn.....
Old May 28, 2016 | 08:30 AM
angrysmileyface
Made that attempt but he had already pulled the front of the engine off and when I tried to put crank.bolt back in, threads seemed munged. I entered this experiance after the fact
Old May 28, 2016 | 11:30 AM
Can use a crescent wrench on the crank snout, to see if it will turn. (assuming the woodruf key is still there.....) I've used that method before. Should be able to turn the engine relatively easily by hand, if you can't, then, yeah, replace it.
Old May 28, 2016 | 12:48 PM
dbbd1's Avatar
dbbd1
^ with the plugs out...
