Hughes plenum vs stock
So I'm getting ready to change my plenum gasket and was wondering how long it will last if I just use the stock plenum vs the Hughes aftermarket kit. How long will it t last if I go back stock. All input is greatly appreciated
As HeyYou said in your other thread, the new gasket should be fine. It will probably last the rest of the life of the engine. The Hughes would be overkill (by most accounts). Sometimes, though, I like overkill.
Alright, I can give some helpful tips on doing this job. First off when you pull the Intake off the truck make sure every surface gets cleaned to a like new finish, and don't cut any corners. Label everything, and be careful with the connectors as they are getting brittle in their old age. Secondly your far better off ordering an Intake manifold gasket kit. Try to find one by a reputable company like Fel-Pro or Dorman. And by kit I mean the complete on that comes with new intake manifold bolts, plenum plate bolts, thermostat, bypass hose for the water pump and more. Its not that much more money and trust me, you will need it. DO NOT TRY TO REUSE THE INTAKE BOLTS. They WILL BREAK as they are designed to be a one time to torque bolt. Secondly the issue really is not with the plenum plate as much as it is with the bolts. Think about that statement. If the cause of the failure really was due to different expansion rates between the steel plate and the aluminum intake manifold causing the gasket to suck in, there would be a heck of alot more issues than that. Aluminum and steel are used together in engines all the time, thats what brings us to the bolts. The bolts have a machined nipple on the end of the threads that helped with assembly at the engine plant, all it does is guide the bolt into the threaded hole straight so they can quickly zip them bolts in for the plenum plate. With that nipple the tapped hole depth and the bolt shank length are the same causing the bolt to bottom out before its torqued properly to the plate. Grind that nipple off the bottom and boom, holds the plate correctly and you will never have an issue again! Another tip, while your in there and have the intake manifold off, you have wide open access to the cap and rotor, great time to go ahead and replace those, and if your valve cover gaskets are starting to leak its easy to get at those now too! Also when you reinstall your intake be careful not to break off the top portion of your Oil Pressure sending unit...(I know from experience)
Sort of dumb question (new to Ram Trucks)
Assume the 2000 V10 has the same problem? Mine is 16 yrs old but only 80K miles
Second owner and yes it was really driven by a little OL on weekends to pull a small horse trailer, stored in the barn when not used.
ps did try to find this answer in the 50 page plenum post
Nope, V-10 has a completely different manifold design, so the plenum failure isn't an issue for them.
Trending Topics
Thanks Good to know. Appropriate everyone for dealing with a newbee Ram owner. I read all I can but sometimes it easier to ask a quick question.
Now all I have to do is find a thread that lists all the V-10 problems..so I have something to worry about
Maybe I should post to the intro forum thread
R
R
Actually, the V-10 trucks don't really have that many problems... Nothing on the scale that you see in the v-8 trucks... Better intake design, heavier duty trans, around here, it is quite common to see them still on the road with 300K miles...... and still the original engine/trans. Yours is new enough that parts availability is still good, but, don't expect much in the way of aftermarket performance parts..... Even finding headers for a reasonable price is pretty much impossible. (No, I do not consider 600 bucks for headers "reasonable".....)
