Need Help with 1999 Ram 1500 no reverse or 3rd gear
Old Aug 6, 2016 | 03:46 PM
joeleerj's Avatar
joeleerj
Default Need Help with 1999 Ram 1500 no reverse or 3rd gear
Hi everyone,
I'm new to this forum and I need help. I have a 1999 Ram 1500 with 5.2 engine and 46re trans. I recently rebuilt the transmission and it now has about 300 mile on it. About 2 weeks ago I was driving and noticed that It wouldn't shift out of 2nd gear. When I and parked to look and see if I could see anything wrong, it was then that I noticed that I had no reverse gear. Got the truck back home and while stationary I shifted from park to reverse, D, 1 and 2. the truck will start in 1st and shift to 2nd but that's it. Also while shifting through the gears I noticed that when I shift into reverse, I can hear and feel the clutch engage but the truck won't move and when I shift from reverse back to park, I hear and feel a clunk. I was thing that the direct clutch was not working but hearing it engage threw me. ANY HELP?
Thanks
Joeleerj
Old Aug 6, 2016 | 03:50 PM
joeleerj's Avatar
joeleerj
I need to clarify, The truck takes off as it should in 1st, not start in 1st.
Old Aug 6, 2016 | 10:06 PM
For the forward gears, unplug the 8 pin connector on the drivers side of the trans. Then start (moving) in first gear, shift to second, then third, at the appropriate speeds. (the trans will have zero automatic function.) If it shifts when you tell it to, into the gear you tell it to, then its just an electronic problem, and likely just changing the governor pressure sensor and solenoid will solve the issue. While you are in there, adjust the bands, and make sure the band strut hasn't simply fallen out.
Old Aug 6, 2016 | 10:32 PM
joeleerj's Avatar
joeleerj
Thanks, I will try that tomorrow and let you know how it goes.
Old Aug 7, 2016 | 11:58 AM
joeleerj's Avatar
joeleerj
HeyYou,
I tried what you suggested and it still only has 1st and 2nd. I will drop the pan today to see if anything has fallen into it. Do you have any other suggestion. I dread taking the transmission out again.
Old Aug 7, 2016 | 07:30 PM
See what you find in the pan. Take it from there. If it isn't something obvious....... may not have any choice but to yank it again.
Old Aug 7, 2016 | 07:36 PM
joeleerj's Avatar
joeleerj
That's what I'm afraid of. I looked in the manual, and the only thing I see that's common to reverse and 3rd, is the front clutch.
Old Aug 8, 2016 | 07:10 PM
Moparite's Avatar
Moparite
Do a pressure test.
http://www.atraonline.com/manuals/se...0/2000_154.pdf
Old Aug 8, 2016 | 07:29 PM
joeleerj's Avatar
joeleerj
Thanks
Can these test be done while the truck in stationary?
Old Aug 8, 2016 | 08:17 PM
dbbd1's Avatar
dbbd1
Originally Posted by Moparite
Thread hijack alert!
If a person were to put a temp sensor in the trans using a pressure port, which one would they use?
