Right taillight and blinker not working
Old Aug 9, 2016 | 05:49 AM
douglassunseri's Avatar
douglassunseri
Default Right taillight and blinker not working
Ok guys im back y'all really helped out last time with my starter relay and ignition fuses. This time my right taillight seems to have went out when I apply the breaks and the blinker stays lit when I put the right signal on any suggestions to fix this problem??
Old Aug 9, 2016 | 07:21 AM
ramsportrocks's Avatar
ramsportrocks
when I bought my SS/T last august I had the same problem on the left side
ended up being corrosion and lack of contact tension inside the bulb socket
cleaned them with folded up piece of 400 grit sand paper and got in there with
a pick and bent them out ever so slightly
and dilectric installed new bulb and no problem since
Old Aug 9, 2016 | 08:00 AM
douglassunseri
Awesome im gonna try that I was gonna go get a test light and a can of electronic cleaner from pepboys when they open, do you think I should spray some of that in the socket?
Old Aug 9, 2016 | 08:01 AM
douglassunseri
And the running lights work fine just the breaks and blinker on the right
Old Aug 10, 2016 | 07:23 AM
ramsportrocks
yep, try giving the socket contacts a cleaning. I don't see where contact cleaner would hurt just make sure its dry inside before grease and new bulb
Old Aug 10, 2016 | 08:08 AM
Change your blinker fluid.
Old Aug 10, 2016 | 12:42 PM
douglassunseri
Alright I still never tried I didn't drive yesterday but im gonna try today
Old Aug 10, 2016 | 12:43 PM
douglassunseri
Yeah definitely 👍👍
