A/C Compressor Squeaking
Old Sep 19, 2016 | 03:02 PM
RamItDammit's Avatar
RamItDammit
Question A/C Compressor Squeaking
If my A/C compressor is squeaking when the truck is running, is that a problem that can be fixed by only changing the A/C compressor clutch, or do I have to replace the whole compressor?
Old Sep 19, 2016 | 03:10 PM
Does the squeak stop when the compressor engages?
Old Sep 19, 2016 | 03:21 PM
RamItDammit
The higher the RPM, the louder the squeak. It changes slightly depending on if the ac is on or not. And, also, it's definitely not a belt. Trust me. I've checked. Lol
Old Sep 19, 2016 | 03:24 PM
Doesn't sound like the A/C then...... if it was the clutch, when it engaged, the squeaking should stop. If it was the compressor, when it disengaged, the squeaking should stop.... I would be more inclined to have a look at the idler, or tensioner pulleys.
Old Sep 19, 2016 | 03:31 PM
RamItDammit
Okay. I've tried lubing every pulley, one at a time, and when I lube the compressor pulley, it stops. Maybe it's something else though. I'll try it again.
Old Sep 19, 2016 | 03:35 PM
What are you lubing on the pulleys? Not where the belt goes I hope....
Old Sep 19, 2016 | 03:41 PM
RamItDammit
I used belt treatment on the belt, and SeaFoam lubricant in the pulley bearings. I used it sparingly, because I was only trying to find the source of the problem.
Old Sep 19, 2016 | 04:55 PM
Take the belt off, and spin pulleys by hand. See what they feel like.
Old Sep 19, 2016 | 05:24 PM
RamItDammit
I'll try it and post an update asap.
