98 Ram 2WD 1500 front hub not tight after torqued
Yes, ball-joint press is a great tool, some people use a hammer and torch, not recommended. While you are in there, make sure control arm bushings are good, not loose, severely cracked or oil soaked. Also check shocks, sway bar link bushings and steering stabilizer shock for looseness.
Put new shocks and struts about 2 years ago. I was surprised the shop that did that did not recommend any of those other components. Again leading me to question the level of expertise and/or experience you get at the "tire shop."
Thanks
Control arm bushings are probably OK, unless rubber is shot. Those rubber grommets are the stabilizer link bushings, they come in a kit, very inexpensive. They will cause rattle if they fail. You may have a shock type device attach to the steering linkage, disconnect and check for looseness or lack of resistance. Steering dampener will help with steering play, but also tends to mask other steering problems.
Finally got to work on the truck again and got it all out back together.
Drives great with new ball joints and tie rods. Worst part was getting the runner boots installed on the lower ball joints.
Just got back from getting an alignment and I have a significant disparity in the length of the tie rods, and started a new thread for that. I have a little play in the steering wheel and will look at the dampener for that.
Thanks for all the help!
