Help! Wheel keeps breaking off!
Hello. I recently bought a 1997 dodge ram 1500 4x4. For some reason once you get the truck above 35 mph or so, and let off the gas, the front of the truck starts bouncing and popping very violently. (without braking) In the midst of the bouncing the wheel studs keep breaking off of my front passenger side wheel. It has broken the studs 3 times. I was told by someone who was beside the truck that the wheel started spinning backwards before it broke off. I assumed that it was trying to lock into 4x4 while driving and when it does the resistance causes the wheel to snap off. However, I removed the front drive shaft and it still does it. Am i just going to have to replace the entire front axel? All of the front suspension has been replaced as well as the hubs. Thank you in advance for any help!
It also sounds like the cad on the front end is locking in when you let off the gas. Might want to check vacuum there and make sure it's working properly.
Maybe I'm missing something obvious, but these are ideas to start you on.
Okay guys, so I messed with it a little bit today. The shifter linkage to the t case was loose and off set a good bit. I reset it and tightened it down. Also while I was under there I turned where the front drive shaft connects and the transfer case makes a clunking noise while spinning. I drove it around at low speeds today in 2 low. It seems to do the jumping worse in 2 low. And it's the only time it will do it at low speeds. The truck seems to have much more power in 2L even though the front drive shaft is removed. When the truck starts doing the jumping at low speeds the engine stalls, since the front drive shaft is not installed, I'm assuming that it is impossible for it to be the front end causing it. Could this possibly be an issue with the transfer case or transmission? The truck shifts well while driving so that leads me to believe that maybe it's the t-case. Thanks for the suggestions guys!
Trending Topics
How do you have 2-low? Did you mean 4-low?
I wonder if your transfer case was swapped out at some point and the 4wd shifter pattern is different than what you think it is...
Then it might make sense. If you are 4wd but think that you are in 2wd, and driving on pavement, you might be breaking things...
