Bypassing the PCM for an external voltage regulator?
Old Jan 1, 2017 | 10:18 PM
AtomicDog's Avatar
AtomicDog
Question Bypassing the PCM for an external voltage regulator?
Does anyone know where I can find clear documentation on how to install an external regulator and bypass the PCM so that the alternator will properly produce voltage to power the truck and keep the battery charged? I ran into a guy today that has a 2001 Ram 1500 2wd truck and his PCM's voltage regulator has failed. He wants to perform a budget repair with an external regulator to keep the truck going.
Old Jan 1, 2017 | 10:38 PM
94Beater's Avatar
94Beater
The alternator already produced regulated 12Vdc. I'm not sure what is it that you are trying to do. PCM voltage regulator will make 5Vdc and maybe other DC voltage, but this is obtain by using onboard DC to DC converter. Its converted from 12Vdc. Not something easily replaceable or upgradable.
If anything you can use additional voltage regulators for the 12Vdc side to make your power system tougher.
Use something like this https://alternatorparts.com/quicktif...rectifier.html
Old Jan 1, 2017 | 11:36 PM
frankie_b_jr's Avatar
frankie_b_jr
Here is a link to a decent write-up... http://www.backyardmechanic.org/how-...jeep-chrysler/.
94 beater, the pcm makes or breaks the ground (iirc) to make the alternator maintain voltage. Unfortunately they do quit working, leaving the option like above or replacing the pcm.
Old Jan 2, 2017 | 12:35 AM
dbbd1's Avatar
dbbd1
Another choice...
https://dodgeforum.com/forum/1st-gen...onversion.html
Old Jan 2, 2017 | 02:26 AM
AtomicDog's Avatar
AtomicDog
frankie_b_jr and dbb1 are in the ballpark of what I'm looking for. The PCM is not properly regulating voltage on this person's 2001 Dodge Ram 2wd truck (which seems to be a very common issue on 2nd gen truck PCMs) and I was looking for a very concise write-up on how to bypass the PCM and wire-in an external voltage regulator to handle the voltage regulation duties.
Another option may be how can the PCM be do-it-yourself repaired to fix the internal regulator?
Old Jan 2, 2017 | 09:43 AM
There is no DIY repair on internal components of the PCM. If it fails, you replace it. The average DIYer doesn't have the equipment to deal with them. Even 99.99% of shops don't. Specialized equipment is required, and isn't exactly something you would find in the typical garage. (private, or commercial....)
Old Jan 2, 2017 | 10:29 AM
gertie240's Avatar
gertie240
he could get this kit, https://alternatorparts.com/external...nator-kit.html but the write is good, read through it and in the end it says to add a 194 bulb to trick the pcm
Old Jan 2, 2017 | 11:07 AM
AtomicDog's Avatar
AtomicDog
What about this for taking a shot at repairing the PCM in do-it-yourself mode?
Old Jan 2, 2017 | 11:15 AM
dbbd1's Avatar
dbbd1
Nice video but my PCM ('99) is pretty well sealed with epoxy and not field repairable by the average joe/Jane.
Old Jan 2, 2017 | 11:21 AM
AtomicDog's Avatar
AtomicDog
dbbd1, is your PCM sealed externally or are you referring to the gell inside of it? A photo would help, if available.
