Auto down power window
Old Feb 12, 2017 | 03:49 PM
02/01Ram's Avatar
02/01Ram
Default Auto down power window
I very happy my 01 Sport came with the creature comfort interior options it has.
The auto down drivers window annoys me, I want to disable it! Personally I would rather have auto up. Is there a way to disable the auto down or reverse it so it's auto up instead?
Thanks
Old Feb 12, 2017 | 04:53 PM
Do you have the third gen body style?
Old Feb 12, 2017 | 05:33 PM
02/01Ram's Avatar
02/01Ram
2nd Gen. I was wrong at the start, I guess I was excited to be getting the truck.It's now in my driveway and it's definitely an 01 not an 02.
Old Feb 12, 2017 | 05:37 PM
Wonder if you could just swap out the window switches, with a switch block from a 99, or some such, and do away with the 'auto' feature altogether....
Old Feb 12, 2017 | 05:48 PM
02/01Ram's Avatar
02/01Ram
I'm hoping your right. I just figured that since I wanted to do it that it would be automaticly more involved than just switchin the switch.
Old Feb 12, 2017 | 05:50 PM
dbbd1's Avatar
dbbd1
My '99 has auto down too, and I don't like it either. I'm thinking that the passenger switch will not swap right in there but maybe swap the wiring around. I will look into it.
Old Feb 12, 2017 | 06:00 PM
02/01Ram's Avatar
02/01Ram
Yea for the most part we aren't thowing coins out the window at the toll both any more. I figure if it's not as easy as switchin the switch there's got to be a relay somewhere to unplug or change. I would much rather it be auto up.
Old Feb 12, 2017 | 06:25 PM
I think the auto feature is actually part of the switch itself. I think..... Could repin the connector, to reverse the switch operation?
Old Feb 12, 2017 | 06:41 PM
02/01Ram's Avatar
02/01Ram
I did a search before I posted and was looking at wiring diagrams. I couldn't find any thing that went that deep. Unless the switch pod pops out from the top without having to remove the door panel I'll have to wait for warmer weather to take the door apart in the driveway to look at and play the wiring and switches.
Old Feb 12, 2017 | 06:43 PM
dbbd1's Avatar
dbbd1
Yes, the auto feature is part of the switch. The window motor is a simple dc reversing motor, it only has two wires going to it. Cut and swap those wires (either at the motor or the switch) and call it good. Up will be down and down will be up, though. You may want to swap the wires on the passenger side too, just for the sake of confusion. Although, it will confuse your passengers.
