high pitch whistle/whine while accelerating
Old Mar 11, 2017 | 08:08 PM
Brando1993's Avatar
Brando1993
Default high pitch whistle/whine while accelerating
i have a 2001 dodge ram 1500 5.2LV8 RWD and its making a whistle/whine noise when im accelerating. it goes away when i let off the gas and it coasts for a few seconds but as soon as i accelerate it comes back. its not knocking when i turn so i dont think its a wheel bearing. its also like 15 degrees and windy today if that makes any difference. any assistance in diagnosing this would be greatly appreciated thankyou.
Old Mar 11, 2017 | 08:22 PM
Can you tell where the noise is coming from? (not the radio is it?) Made any changes to the truck recently?
Old Mar 11, 2017 | 08:25 PM
Brando1993's Avatar
Brando1993
no i turned off the radio and all i have done recently is change the rotors calipers and brake pads. also changed out my spark plug wire going from computer to distribution cap
Old Mar 11, 2017 | 08:26 PM
So can you tell where its coming from? Front of the engine? Trans? Elsewhere?? Does it make the noise at low enough speeds, you could have someone walk beside it, and try and find it?
Old Mar 11, 2017 | 08:29 PM
Brando1993's Avatar
Brando1993
yeah it sounds like its coming from the front part of the engine now that u say it, i popped the hood but i cant pin point exactly where its coming from.
Ramman18's Avatar
Ramman18
It's just the turbo spooling up!
Totally normal
Old Mar 11, 2017 | 08:30 PM
Brando1993's Avatar
Brando1993
there was a high pitch whistle before but it wasnt as bad as this and i read somewhere it could have been a vacuum housing but it eventually went away
Old Mar 11, 2017 | 08:31 PM
Ramman18's Avatar
Ramman18
Actually, if you recently did brake work, it is probably there. Pads squealing or something. Or if you took off the air box assembly, and didn't get it all the way on, it will whistle. And what spark plug wire goes from computer to distributor??? I need to check mine, probably got a virus. . .
Old Mar 11, 2017 | 08:34 PM
Brando1993's Avatar
Brando1993
whatever plug goes from the engine to the cap that tells what spark plugs to fire off, whatever its called
Old Mar 11, 2017 | 08:35 PM
Brando1993's Avatar
Brando1993
and i havent messed with the airbox but the whistle goes away when i let off the gas even at 40 mph so idt its the brakes
