Injector ticking
Old Mar 28, 2017 | 08:14 PM
Jcapps29's Avatar
Jcapps29
Default Injector ticking
97 5.9l got a ticking sound that is always there ...When I listen to the injectors with stethoscope they are pretty loud..Put it on vavle covers hear some lifter tick no way as loud as injectors...Now another problem is going down the road I start to get a stumble or cutting back ....Are injectors suppose to be loud ?
Old Mar 28, 2017 | 08:46 PM
97ramrod1500's Avatar
97ramrod1500
Yes injectors make a fairly loud ticking noise. That's one of the reasons most manufacturers put pads under the hood and plastic covers over the engine. They help absorb a lot of the injector ticking. That ticking is the injector opening and closing to allow fuel into the cylinder.
Old Mar 28, 2017 | 08:50 PM
Jcapps29's Avatar
Jcapps29
Ok any idea why I'm getting a miss or stuttering at driving speeds ..Best I can say is if I'm going down the road and I push the overdrive button to off the truck starts almost like missing ...
Old Mar 28, 2017 | 08:51 PM
Jcapps29's Avatar
Jcapps29
Truck is 4wd with 183,000
Old Mar 28, 2017 | 09:32 PM
97ramrod1500
Could be a number of things. How are your plugs, wires cap and rotor? When's the last time a tune up was done? Has the plenum been fixed?
Old Mar 28, 2017 | 09:33 PM
How are your plugs/wires/cap/rotor? Has the plenum been fixed? How old are the O2 sensors?
I sense a pattern here......
Old Mar 28, 2017 | 10:47 PM
Jcapps29's Avatar
Jcapps29
Plugs ,wires,cap,rotor new...Plenum not sure, there is a small amount of oil residue in throttle body..But what's​. Weird to me if you turn o/d button off it really acts up but no irractic RPM movement... Could bad Plenum make it do this...I'm changing O2 sensor this weekend
Old Mar 28, 2017 | 11:16 PM
Jcapps29's Avatar
Jcapps29
Just noticed the sticky on Plenum..I will check tomorrow with magnet 👏
Old Mar 29, 2017 | 08:33 PM
Jcapps29's Avatar
Jcapps29
Well don't know if gasket has been replaced but the factory metal Plenum plate is still there....
