Fuel pump replacement
Old May 18, 2017 | 07:56 PM
  #21
horne's Avatar
horne
I know i changed these out before but its never been this loose......
Old May 18, 2017 | 08:17 PM
  #22
You might be able to tighten 'em up a bit with a small screwdriver..... but, getting the PDC out is not a trivial undertaking.
Old May 18, 2017 | 08:48 PM
  #23
horne's Avatar
horne
not easy is understatement...did get the loose connections taken care of though....now back to nothing....cant figure out why it attempted and now zero.....starting over again.. .jumpered ASD and pump relay..nothing...
Old May 18, 2017 | 10:06 PM
  #24
Check the fuses.
Old May 19, 2017 | 03:03 PM
  #25
horne's Avatar
horne
fuses are still good...all voltage issues remain the same.. still nothing. Wish I knew what made it attempt to start...I tried to recreate voltage testing at the injectors ( as this was the last step before it breathed life again) but no luck
Old May 19, 2017 | 08:21 PM
  #26
If you still aren't getting power, even with the ASD relay jumped, then the problem is further upstream than that.... Check the wiring diagram, and then follow the wires back to where power comes from. See what you find.
Old May 20, 2017 | 05:53 PM
  #27
horne's Avatar
horne
will do...really has me stumped why it attempts to start after sitting for a few hours. Makes no sense at all
