No power Need Help ASAP!!
Old Jun 14, 2017 | 08:23 PM
I ran the autolites for a while, as the a/c delco plugs weren't in stock. They worked fine.
Don't bother spending money on rare-earth plugs, our trucks hate them. Many a member has had the hard to find miss, that was solved by changing out their relatively new, high dollar spark plugs, for the cheap copper fellers.
Old Jun 14, 2017 | 09:58 PM
Randyn Collins's Avatar
Randyn Collins
Ok good to know. They looked a little worn down so I'll still replace them but I won't waste money on the best plugs then. One more question. What should I do about the o2 sensor. I'm a very experienced welder but I don't have a welder at home. Will I be fine just driving for a while without it. The previous owner was ( what I can tell from the kind of work done to this poor truck ) pretty dumb. Thanks for all the quick replys.
Old Jun 14, 2017 | 11:14 PM
You'll be fine for a while. Just gas mileage will suffer. (I can't bring myself to call it 'fuel economy', there is nothing economical about these trucks. )
I would go looking for the connectors for the O2 sensors. If the check engine lite isn't constantly on, then, they had do something about them. My guess would be O2 simulators, that just send a switching signal to the PCM, does nothing for gas mileage, but, fools the computer into thinking the sensors are there, so the lite doesn't come on. Gonna need a lite, maybe a mirror, and a third elbow to find the connectors. For the front O2, it is right on top of the trans, just behind the bellhousing. At least, that's where it *should* be.....
Does the check engine light test when you first start the truck?
Old Jun 15, 2017 | 06:07 PM
Randyn Collins
Yea the check engine light constantly stays on because it was an automatic before so it's throwing all sorts of tranny sensor codes. But no spark plugs or o2 sensor is showing up on my reader. There is a TPS/ACC code but the gas isn't bad anymore I've checked the new one with multimeter.
Old Jun 15, 2017 | 08:43 PM
Probably have simulators plugged in the, and one of them may have failed.....
Old Jun 21, 2017 | 10:16 PM
Randyn Collins
Ok so I've been driving it to work and around town for a couple days. Ended up getting bosh platinum for it as they were only like a dollar more.. That helped a lot with performance. Then I have found 3 badly leaking fuel injector seals. Replaced them and a huge difference. Runs pretty good under load now except when taking off exactly at 3000 rpm' s the motor cuts out hard, then bucks and jumps until I shift. Any ideas what that could be. Also the fuel pump and fuel filter are now brand new.
Old Jun 21, 2017 | 10:24 PM
dbbd1's Avatar
dbbd1
^ You should have saved the extra $8.
Old Jun 21, 2017 | 10:45 PM
Randyn Collins
I trust the bosch plugs. My dad ran them in his jeep that had the same 5.2 magnum in it. He ran it for 5 years straight without changing out the plugs.
Old Jun 21, 2017 | 10:51 PM
Randyn Collins
One more thing I just remembered. When I shift gears or just push in the clutch sometimes it drops below 500 rpm's or stalls/ almost stalls. Doesn't happen all the time but pretty regular. Could it possibly be a weak Cool? Any ways to test....... Thanks ally.
Old Jun 21, 2017 | 11:01 PM
dbbd1's Avatar
dbbd1
Cleaned or replaced your IAC lately?
