No power Need Help ASAP!!
Old Jun 24, 2017 | 09:32 PM
  #31
The sensors are different lengths, as the flexplate/flywheel are different diameters. If it works, run with with it.
Old Jun 29, 2017 | 08:45 PM
  #32
Randyn Collins's Avatar
Randyn Collins
This has nothing to do with engine but I don't feel like it needs a whole new post and can't find anything on it. Does anyone know what I can do for a speedo. It used to run off the transfer case but now the case that's on the 5 speed doesn't use that method. Can I just get an abs/ speedo combo for the rear diff??? Then just wire it up? Thanks
Old Jun 29, 2017 | 08:53 PM
  #33
still have your old t-case?
Old Jun 29, 2017 | 09:02 PM
  #34
dbbd1's Avatar
dbbd1
A gps unit?
Old Jun 29, 2017 | 11:39 PM
  #35
Randyn Collins
Yes I still have the old t-case and the speedo assembly and it works. I plugged it in and spun it by hand. I would just swap out the output shaft housing ( or whatever the proper name is ) but there different lengths for some reason. The one that's on there now is attached to the 5 speed and is about 6 inches longer than the other t- case which was attached to an auto. Don't know why they'd be different. And also if the drive shaft has been changed to.
Old Jun 30, 2017 | 09:38 AM
  #36
There is also the matter of the gear on the output shaft itself. I don't know if the splines are there on the newer versions...... wouldn't hurt to look I suppose.
Is the transmission length different, or the t-case?
Old Jun 30, 2017 | 12:53 PM
  #37
Randyn Collins
Not completely sure. I'll look when I get home. I think the t cases are the same length. The auto tranny and manual look pretty identical except it looks like there's and extension type box after the tranny and before the t case on there now. Is that an overdrive? Pretty clueless to this kind of thing as I've never rebuilt a tranny. I have done motors and t cases though. My dad's truck is a 99 and reads off the rear diff ( pretty positive ) and I can get the whole set up for only like 35 bucks so I think I'm going to try that out.
Old Jun 30, 2017 | 01:47 PM
  #38
Probably just an adapter for the t-case, as opposed to the extension housing for the 4x2 flavor.
I *think* the manual trans is a couple inches shorter, but, not 100% sure on that. If the t-cases are the same length, just take the input shell from the manual trans t-case, put it on the original, install it, and get your speedo back.
Old Jun 30, 2017 | 03:06 PM
  #39
Randyn Collins
Ok so i
Old Jun 30, 2017 | 03:08 PM
  #40
Randyn Collins
Ok so if the transfer case measures the same from where it bolts to the tranny/ adapter as the Auto does, the output ( driveshaft input ) housing length shouldn't matter?? It doesn't hold force or pressure of the driveshaft? I just don't want to seriously damage drivetrain parts. Thanks.
