Engine/transmission swap
Old Jul 10, 2017 | 12:26 PM
chuck1988's Avatar
chuck1988
I've been looking for kits, I think that summit racing equipment has what I'm looking for, in the price range I can afford. Is summit ok?
Old Jul 10, 2017 | 12:43 PM
Summit is fine, they are just the retailer. Whose name is on the kit?
Old Jul 10, 2017 | 01:12 PM
chuck1988's Avatar
chuck1988
ATP rebuild kit, Transgo shift kit and sealed power engine kit.
https://www.summitracing.com/parts/a...995/make/dodge
https://www.summitracing.com/parts/trg-tf-3
https://www.summitracing.com/parts/f...-311/overview/ (not the exact kit I'll get, I have to measure and inspect 318 block and cams first.)
Old Jul 10, 2017 | 03:37 PM
Transgo is definitely good, as is sealed power. For the trans kit, check out the viper series of kits at transmissioncenter.net. If you are going to rebuild it, might just as well improve it. Right?
Old Jul 10, 2017 | 04:12 PM
chuck1988's Avatar
chuck1988
Good to know the kits are decent. As for the viper kit, if I could afford that, I would just have mine rebuilt professionally.
Old Jul 31, 2017 | 02:31 PM
chuck1988's Avatar
chuck1988
Originally Posted by chuck1988
I wouldn't mind upgrading some issues that they had. My main focus is on rebuilding the transmission first. The only reason I parked it was because the transmission went. Lost all motion forward and backward, 4 wheel drive. The engine was still running decent. I don't remember knocks or other noise. My thought was the engine is out, its high mileage, maybe rebuild it then.
I've been thinking about this for a couple weeks. The day I had to park my truck, I remember starting at an intersection, the engine revved and after a couple seconds, the truck began to move, then on the way back home, I was climbing a small hill and about half way up, that's when things stopped. I lost all gears, forward and reverse. I blame the transmission, because that's a big issue with dodge. But, loosing forward and reverse at the same time, would that point to a bad transfer case or could it still be the transmission?
Old Jul 31, 2017 | 02:56 PM
Not much to go wrong with the t-case, and it usually gives plenty of warning before it gives up the ghost.
Old Jul 31, 2017 | 03:03 PM
chuck1988's Avatar
chuck1988
I have the transfer case out, if I spin the shaft that connects the transmission, I would see the drive shaft connection turn?
Old Jul 31, 2017 | 03:24 PM
So long as it isn't in neutral.
Old Aug 2, 2017 | 09:30 AM
chuck1988's Avatar
chuck1988
I rotated the transmission side when I got home, both shafts did spin. I don't know if I mentioned it, the transfer case was already out of the truck. If things go decently, this Saturday my 95 engine and transmission will be out. Maybe some prep on the 97 with disconnect. Things are moving along. Will have details about how things go. Hopefully my experience can help someone else too.
