Unexplained Drivetrain Noise When Partial Throttle
Old Sep 24, 2017 | 01:45 PM
Edwin3912's Avatar
Edwin3912
Yeah you wouldn’t think it’s the catalytic converter that’s causing it. Keep us updated
Old Sep 24, 2017 | 09:23 PM
Edwin3912's Avatar
Edwin3912
I deleted the cat today and keeps doing the same noise.
Old Sep 25, 2017 | 11:07 AM
Make sure all your heat shields are secure.
Old Oct 3, 2017 | 06:36 PM
Total_War's Avatar
Total_War
Hey Edwin3912
After driving from work. Put my truck on the hoist to look around
My driveshaft is the definite cause of the vibration
It's rubbing against the fuel tank strap
Now our suspicion is the driveshaft is out of balance and secondly the fuel tank strap might be stretched a little
It's plain as day that the driveshaft is rubbing on it
Tomorrow my driveshaft and 4x4 shaft goes to pats driveline in Calgary for rebalancing
Then I'm​​​​​​ going to look over that fuel tank strap
I'd take your truck for a drive down the road. Crawl under and look for a rub point on your driveshaft
I'll have results tomorrow once I get my shafts back. Hoping there's no damage to the driveshaft. Doesn't feel like it
Old Oct 20, 2017 | 01:03 AM
Total_War's Avatar
Total_War
Well after much troubleshooting the end result was my rear pinion bearing and race was toast
They came out almost looking like the were rusted, the rear pinion bearing was crunching when you tried touching and checking it. Mechanic said I was lucky my rear end never exploded
Truck now runs good and smooth with no more vibration
My mechanic installed a SKF Master Bearing Kit and replaced all bearing in the rear differential. So anyone else that's starts to experience similar symptoms, if you've done everything we have checked and listed.
Pretty good chance this could be your problem
Good luck out and there and have fun
Old Oct 20, 2017 | 11:28 AM
Edwin3912's Avatar
Edwin3912
I had the same mechanic that worked on my differential have a look at it and it turned out that the problem was a spacer on the pinion. There was a lot of play on it.
