46rh transmission issues
Old 10-23-2017, 10:49 AM
Christina Knight's Avatar
Christina Knight
Christina Knight is offline
Default 46rh transmission issues
I have 94 Dodge ram.. when my is cold it shifts and drives fine. When my truck starts to warm up it won't shift.. I have no gears .. I'm mean I lose reverse drive etc..I changed the fluid and filter.. and there was no change in what it was doing.. what could it be...
Old 10-23-2017, 10:50 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
Find anything interesting in the pan when the fluid/filter was changed?
Welcome to DF! Going to move this to the second gen ram section for ya.
Old 10-23-2017, 01:25 PM
Christina Knight
There wasn't anything in the fluid . But on the magnet they said was full of metal dust. But they said it was normal for that age of vechile
Old 10-23-2017, 02:26 PM
HeyYou is offline
How many miles on it?
When it warms up, will it move at all? Or does it act like its in neutral?
Verify fluid level. Get the trans warm, and check it in Neutral. Checking in park will give an artificially high reading.
Old 10-23-2017, 02:36 PM
Christina Knight
I've done all that.. the fluids check out good..and it acts like it is in neutral..
Old 10-23-2017, 02:37 PM
HeyYou is offline
Unfortunately, I think that means its time for a rebuild. First three gears (and reverse) are completely mechanically controlled, no electronics involved.....
Old 10-23-2017, 02:39 PM
Christina Knight
Awesome.. .. thanks for your help.. I appreciate it
Old 10-23-2017, 02:41 PM
HeyYou is offline
Sorry to be the bearer of bad news...... Good Luck, and let us know what you learn.
Old 10-24-2017, 06:08 AM
Moparite's Avatar
Moparite
Moparite is offline
Old 11-16-2017, 05:21 PM
Christina Knight
While heres an update .. I had the transmission rebuilt and got to drive it for a total of 2 days just for it to mess up again. Went back to the shop and they said that the overdrive wasn't getting any fluids.. okay.. but this was after they tried to say my rear end was locked up and that was the reason the tranny went out again.. turns out they didn't take off the parking brake. Now that I have my truck back again it still slips from 2nd to 3rd and the front seal is leaking. Plus they lost one of the bolts to my drive shaft and put one in that has 4 washers behind it and they also put weights on the top and bottom of my drive shaft.. I mean the transmission just looks a whole lot smaller then my old one.. so I need help on a good transmission place in okc.. please help
