2001 ram 1500 4x4 5.2 hard start won't idle
Old Nov 27, 2017 | 10:25 AM
Robertsirrah's Avatar
Robertsirrah
Default 2001 ram 1500 4x4 5.2 hard start won't idle
Ok guys I am in trouble and I need your help.
Problem: my truck only starts when the gas pedal is to the floor. I have to keep it on the floor to keep it running. It Will not idle.
Things I did before the problem: intake gasket,IAC sensor,Fuel injectors,Plugs,wires,cap,rotor,coil,off valve hose,thermostat,thermostat housing.
CURVE BALL: i had it running with the air box off after I did all this work and It was running fine but I heard what I thought was a vacuum leak so I started looking around. Well I thought to myself. Maybe it's just the throttle body being wide open and I'm not used to the sound. I put my hand over it and the (iac) area sucked my hand to it. It stalled out. Now I have my problem....
Thank you all in anvace for taking time out of you day just to read this and help out a stranger..
Old Nov 27, 2017 | 10:30 AM
What year is your truck? What motor?
Sounds like the temp sensor the PCM uses isn't working, isn't hooked up, or has a bad connection.....
Welcome to DF.
Old Nov 27, 2017 | 12:19 PM
Robertsirrah
Ok thank you. I know it is not plugged in because i acciaccidentally broke the sensor and haven't replaced it yet. I will be doing so within the next half hour.
Old Nov 27, 2017 | 12:38 PM
Yup. Without that sensor, the PCM thinks it's -40 degrees outside, and positively DUMPS fuel, trying to get a mixture that will burn. Floods the engine out in seconds. It simply will not run that way. (unless it really is -40 out......)
Old Nov 27, 2017 | 12:42 PM
Robertsirrah
Well now it makes sense. But AutoZone can't get me one till tomorrow.... off to another part store
Old Nov 27, 2017 | 01:14 PM
Robertsirrah
FIXED IT!!!!!! You are the man!!!!! A huge wait was just lifted from my shoulders. It's my only ride and it's my work truck. Thanks a million man.
Old Nov 27, 2017 | 02:45 PM
Did your sensor come in early?
Old Nov 27, 2017 | 03:03 PM
Robertsirrah
Different part store. O'rileys.
