control arms
control arms
Hey everyone.. How can I tell if my control arm bushings are bad? Looking at the bushings, they are cracked or weather checked. I can visually see the cracks in the rubber bushing. But I haven't figured out a way to actually tell if there's any play in them. I thought about getting a pry bar with the front end suspended in the air and seeing if I could get the axle to move, but I work on this by myself 99% of the time with no extra eyeballs or hands to assist me. Are the bushings a commonly replaced part? Is it easier just to buy a new set of control arms and slap them in vs swapping bushings?
Thanks Guys.
Thanks Guys.
I've got a ball joint press, but probably wrong tool for the job. Was hoping there might be another way, but unloaded suspension makes the most sense. So when it's up in the air, get a prybar under the axle on the front side and lift up (pushing the axle to the rear) to see if there's any play? changing bushings or the entire control arms would require an alignment after?
Eh, my bushings were visibly cracked since I bought it in 2001. I replaced the lowers with Skyjackers in 2010. They weren't hard at all since they just drop right out. The uppers though are much harder but I left those stock for my little 3" lift kit. My bet is you'd be better to spend time, money, and energy on something more important like a steering gear, ball joints, tie rods, etc. (something that makes more of a noticeable difference).
I don't think a ball joint press is the best tool for the job..... If you weren't on the other side of the friggin' continent, I'd just have ya bring it over, and we could do it up. If you have another form of transportation, might be able to get a shop to press the bushings out/in for ya..... I know we did that for folks for cheap. Replacing the entire arms might turn out to be cheaper though.... and it is certainly easier.
He's in Spokane IIRC while I'm north of Seattle but still too far to help. I agree that just swapping in replacement arms is way easier, faster, and will have a greater effect at tightening up the suspension. I noticed a tighter feel when going to the T steering although that came with its own problems.
Get the Redhead asap. But be careful as it will be very tight with little return. It may loosen up a bit over time but mine is still quite tight after a year. Makes me drive with a death grip but at least I'm not soiling myself by swerving all over the road going over passes.
Trending Topics
I installed these control arms on my truck when I rebuilt the front suspension a while back and have been very happy with them - no issues whatsoever.
https://www.spohn.net/shop/1994-1999...2500-3500.html
