4 door second gen wheel base?
Old Dec 3, 2017 | 06:33 PM
Jgray21's Avatar
Jgray21
Default 4 door second gen wheel base?
Can someone please tell me what the wheel base is on the 4 door gas secon gens? And what it maches up with? Example. Ext cab long bed maybe? Plans are to buy a second gen dodge diesel and put the 4 door cab and bed that came on the gas trucks but need the wheel base to match up as close as possible. All help is appeciated
Old Dec 4, 2017 | 07:36 AM
Do you already have the diesel truck? There are a variety of cab/bed configurations....... and they all came with the gas, or diesel engine. They didn't really discriminate. What exactly do you have, and what do you want to end up with?
Old Dec 4, 2017 | 08:00 AM
rayaa3's Avatar
rayaa3
http://dodgeram.info/2001/dimensions.html
2001 info across the 1500/2500/3500 club/quad/chassis cab configs.
Old Dec 4, 2017 | 10:06 AM
Jgray21's Avatar
Jgray21
I just got rid of a mega cab. I' wanting to know if a ext cab long bed has the same wheel base as the 4 door short beds so I can get a ext cab long bed diesel and swap the cab and bed with the 4 door short bed and still bolt up on the frame and fender wells match up
Old Dec 4, 2017 | 10:28 AM
Nope. Long bed, and short bed, use different frames, regardless of cab.
Old Dec 5, 2017 | 07:48 PM
Jgray21's Avatar
Jgray21
what I'm trying to get at here is will a 4 door cab and short bed swap out with a ext cab long bed and the fender wells still line up where they are wanting to. I'm getting a ext cab long bed and wanting to put a 4 door cab and short bed on it if it'l work
Old Dec 5, 2017 | 07:53 PM
brian102's Avatar
brian102
the short bed xcabs have a shorter wheelbase/frame. mine is about 138" center to center if that helps.
Old Dec 5, 2017 | 08:05 PM
Jgray21's Avatar
Jgray21
I figured the short bed ext cab wouldn't work but hoping the long bed ext cab would be close enough to make work
Old Dec 6, 2017 | 09:29 AM
The four-door cabs are the same lenth as the extended cabs on the 2nd gens. Rear doors are only 'half' doors.....
