Finally after a few years I got to the plenum repleament.
Old Feb 11, 2018 | 11:00 PM
  #31
BigRedRam95's Avatar
BigRedRam95
These are just a few pictures of the blowen gasket.
Attached Thumbnails Finally after a few years I got to the plenum repleament.-img_1644.jpg   Finally after a few years I got to the plenum repleament.-img_1645.jpg   Finally after a few years I got to the plenum repleament.-img_1647.jpg   Finally after a few years I got to the plenum repleament.-img_1646.jpg
Old Feb 12, 2018 | 07:45 AM
  #32
true blue's Avatar
true blue
BigRed...does your intake have an EGR??? I've never seen that well sticking outta the center divider before.
Old Feb 12, 2018 | 09:02 AM
  #33
Yeah, the OBDI trucks had EGR, the center divider went away in 98, or 99.
Old Feb 12, 2018 | 10:20 AM
  #34
true blue's Avatar
true blue
Are you using any special grade aluminum for the fan spacer or just what's cheapest?
Old Feb 12, 2018 | 02:01 PM
  #35
jtcowan's Avatar
jtcowan
I had to replace my 95 ram plenum gasket twice. I found the plenum bolts were loose. so I replaced with new bolts and used blue Loctite on the bolts. no problems so far so far with plenum.
Old Feb 12, 2018 | 06:52 PM
  #36
BigRedRam95
I deleted the egr on the intake I swapped in. The aluminum is .055. My dad worked for an aluminum plant. It was a scrap sut off a coil. You could use something thicker but there's really no need and it would make it harder to cut. As for the plenum I used the Hughes kit and also used blue loctite on the new bolts.
Old Feb 24, 2018 | 03:51 PM
  #37
BigRedRam95
Need so advance guys. I'm replacing my steering box. The new borgeson box. It has what looks like atf in it now. It's red. I'm using the factory pump and replacing the hoses. What fluid should I use? I can get power steering fluid from the parts store that list the correct fluid for our trucks. But the box has red in it.
Old Feb 24, 2018 | 05:52 PM
  #38
Use what the folks that made the box suggest. The pump doesn't really care.
Old Feb 24, 2018 | 08:32 PM
  #39
BigRedRam95
the directions with the gear box says to run what the factory calls for. I just find it weird that the fluid in the box is red. To my knowledge ps fluid is clear. Unless they make red.
Old Feb 25, 2018 | 09:38 AM
  #40
Likely trans fluid in the pump. I don't recall what the factory suggests, I personally use PS fluid, and yes, it is clear.
