Truck stalls
Old Jan 2, 2018 | 05:22 PM
Weld4it's Avatar
Weld4it
Default Truck stalls
I have a 1999 Dodge Ram 1500 5.9 The truck Randomly stalls.While Driving and while idling. the gauges all go dead and no bus appears on the odometer. Also the Fuse box under the hood makes a clicking sound. The guy i purchased the truck from said he has put a new ecm in it. Is there a way to tell? Or can someone point me in the right direction hear? Can a bad fuse box make no bus appear?
Old Jan 2, 2018 | 07:22 PM
No Bus means the cluster has lost communication with the PCM. Unfortunately, there are a LOT of possible causes... Will the truck start right back up when it dies?
Old Jan 2, 2018 | 07:32 PM
Weld4it's Avatar
Weld4it
It has crunk up right after before but recently no it will not just turn over and I can go outside of the truck wiggle the plug closest to the driver side on the pcm and it will crank up seems like it turns the fuel pump on because every time it shuts off the fuel gauge is dead
Old Jan 2, 2018 | 07:42 PM
Weld4it's Avatar
Weld4it
this is what the pcm looks like and also the noise my fuse box was making
Attached Thumbnails Truck stalls-26637827_1627163347369795_1252424368_n-1-.jpg
Old Jan 2, 2018 | 09:28 PM
Is that burnt there in the lower part of the pic? If it is..... time for a new one.
Old Jan 4, 2018 | 11:41 AM
Weld4it's Avatar
Weld4it
Im assuming it is burnt out. Is there anyway i can swap one out of a junk yard. aint really got a extra $300 for a new computer
Old Jan 4, 2018 | 12:17 PM
You could grab one from the yard, providing you can find one...... (has to be 99 though, I think to much changed on either side of that.) And you will have to have it flashed to your vin if you want ABS and Airbags to work right. (at all.....)
Old Jan 4, 2018 | 12:21 PM
Weld4it's Avatar
Weld4it
What if the numbers on the computer match up? Should be same computer right? i don't much about the computers and stuff
Old Jan 4, 2018 | 12:36 PM
98 was kind of an odd year, with some serious mid-year changes..... 2000 changed sensor values for the trans..... so, to be safe, you need the 99 PCM, with the same engine/trans that you have in your truck. (could conceivably have it flashed if only the engine is different.....) but, you will have to get it flashed to the correct VIN, in order for ABS, and SRS to work.
Old Jan 4, 2018 | 12:40 PM
Weld4it's Avatar
Weld4it
So if i get one out of junkyard same year model same motor trans. then truck will run fine without abs? and airbags?
