Operating temp
Old Jan 3, 2018 | 08:38 PM
brewman's Avatar
brewman
Originally Posted by Moparite
I have a 180 in mine and in 20* weather mine stays just under the 200 mark. Replace the t stat. And drill a small hole in it before you put it in(read # 14).
https://dodgeforum.com/forum/2nd-gen...p-bleed-2.html
+1 for the 180. I have one in my 5.9L v8, and it has no trouble heating up in the winter (18 this morning in GA), and is cooler in the summer.
Old Jan 3, 2018 | 10:31 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by jkeaton
Over time, just like any other engine, running cold can lead to a build up of carbon deposits.
Also, if the engine can't get up to temp, it won't burn off water condensation in the oil. That can lead to sludge.
Originally Posted by BrandonBuc'em
but when they fail dont they usually cause the engine to overheat?
They usually fail open and cause the engine to run cold.
No need to drill. They all bleed air and you're reducing the efficiency of the thermostat when you do this
http://www.stant.com/index.php/engli...rmostats/faqs/
MY THERMOSTAT HAS A JIGGLE PIN BUT THE STANT THERMOSTAT DOESN'T. WILL A STANT THERMOSTAT STILL WORK?
Yes. Many thermostats have a “jiggle pin” that allows trapped air in the cooling system to pass through the thermostat and be released from the system. Some Stant thermostat do not use have a jiggle pin. These thermostats will have a "bleed notch” or other method of removing air from the system.
Old Jan 4, 2018 | 11:19 AM
BrandonBuc'em's Avatar
BrandonBuc'em
I'll have to get in there an replace it. Thanks guys! Any tips? I know the accessory bracket can be removed with the ac compressor and alt installed. That's the only thing I need to get out of the way? Any other parts to replace while I'm in there? I already got a feel pro seal. The water neck is a little over a year old. Recommendations?
Old Jan 4, 2018 | 12:18 PM
If you can move the big bracket out of the way, that's all ya really need. Might want to look at the bypass hose from the water pump, to intake while that bracket is moved though......
Old Jan 4, 2018 | 02:07 PM
BrandonBuc'em
I replaced that little tube from the water pump a little over a year ago, same time as the thermostat. Think it's worth replacing?
Old Jan 4, 2018 | 03:38 PM
Probably not necessary then. Wouldn't hurt to look at it though, make sure clamps are tight.......
Old Jan 4, 2018 | 11:06 PM
BrandonBuc'em
ive looked at a cpl videos on youtube and they seem to get it done without taking the accessory bracket off. i had to replace some pulleys tonight and looking at it, it looks really tight. i think im just gonna take it off. thanks everyone, especially HeyYou. you are always so helpful. thanks a bunch man
