Operating temp
Old Jan 3, 2018 | 12:47 PM
BrandonBuc'em's Avatar
BrandonBuc'em
Default Operating temp
I installed a 190 thermostat in my truck but lately it doesn't get near that. It's acting as if I installed a 150 or 160 thermostat. Can this have any bad effects on my truck? Besides.... No heat
Old Jan 3, 2018 | 12:55 PM
Over time, just like any other engine, running cold can lead to a build up of carbon deposits.
Old Jan 3, 2018 | 01:02 PM
BrandonBuc'em
Ok so what are the steps to diagnose this?
Old Jan 3, 2018 | 01:44 PM
How long ago did you install the t-stat? Did you burp the system correctly, sure you got all the air out?
Old Jan 3, 2018 | 01:50 PM
BrandonBuc'em
its been over a year since i installed that 190. the problem is just surfacing maybe for the last month or so. my truck sits allot. i drive the company truck most of the time.
Old Jan 3, 2018 | 02:08 PM
That looks a lot like a failed thermostat.......
Old Jan 3, 2018 | 04:17 PM
BrandonBuc'em
but when they fail dont they usually cause the engine to overheat? this thing functions like a good t stat but at a much lower temp. that t stat is a real bugger to get to. is it possible to get to without taking off the accessory bracket?
Old Jan 3, 2018 | 05:05 PM
brewman's Avatar
brewman
If the thermostat fails open, and it's winter time, your engine probably won't reach operating temp which is what you're seeing.
Old Jan 3, 2018 | 06:21 PM
There is a tab on the front of the thermostat housing, that makes it fun to get out with everything else still in place. Grind off the tab, and life becomes a lot easier.
Get a stant superstat. NOT a safety stat. Those suck, as they fail far to easily.
Old Jan 3, 2018 | 08:03 PM
Moparite's Avatar
Moparite
I have a 180 in mine and in 20* weather mine stays just under the 200 mark. Replace the t stat. And drill a small hole in it before you put it in(read # 14).
https://dodgeforum.com/forum/2nd-gen...p-bleed-2.html
