Can someone explain to me how to Replace my Motor Mounts???
Old Feb 21, 2018 | 11:03 PM
GageD1's Avatar
GageD1
Lightbulb
Originally Posted by jkeaton
fixed the error. please accept my apologies.
since your a moderator as well, how do I go about to being able to post pictures in my album again, it said I'm unable to [ost pictures until I contact an admin...
Old Feb 21, 2018 | 11:50 PM
GageD1's Avatar
GageD1
Talking
To all, you guys finally found the page where to install the engine mounts thank you for the help!
Old Feb 21, 2018 | 11:56 PM
GageD1's Avatar
GageD1
Exclamation
My other question is do I need restriction pads for my motor mounts for my 1500? I searched them up and they sell for 2500 and 3500s so it has me thinking?
Old Feb 22, 2018 | 12:37 AM
Ramman18's Avatar
Ramman18
Apology accepted, Keaton. Thanks for being upstanding. It's a main reason I remain on this forum (me and the other five, ha).
Glad you've found some good info GageD1. I hope you can just jack up the trans but it may hit the body since it rides so close. Of course, I have the manual so it may be taller.
I've never heard of a "restriction pad." What does that do? Sounds like a personal hygiene product, lol.
Old Feb 22, 2018 | 12:42 AM
GageD1's Avatar
GageD1
Lightbulb
Lol yea I keep searching and they come up with the 2500s and 3500s but I attached the pic from the manual and they're no.3 on the diagram..
Attached Thumbnails Can someone explain to me how to Replace my Motor Mounts???-motor-mountr-restricktion-pad.jpg
Old Feb 22, 2018 | 12:44 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by GageD1
I appreciate the help big time, thank you for the link to the manual, that way I can do a specific search to save time. Also, I had planned on loosening the bolts then jacking up the tranny slowly and then switching out the mount if I can. Thank you again and taking it easy on the newbie lol
When I did my tranny for some reason it wouldn't Jack up high enough until I disconnected the 4wd lever from the trans
Old Feb 22, 2018 | 12:48 AM
Ramman18's Avatar
Ramman18
Oh, those. I just re-used my old ones. They kinda just pealed off the OE mounts so I put them back on. New mounts didn't come with. If they sell them for 2500s, it's the same part for 1500s. The mounts used for the V8s are way overkill and I think they're the same on the cummins. Almost everything is interchangeable between the models in our generation.
Old Feb 22, 2018 | 12:55 AM
GageD1's Avatar
GageD1
Lightbulb
So worse case scenario could I get them from AutoZone or napa? I attached an eBay kit of what I would assume would fit them
Attached Thumbnails Can someone explain to me how to Replace my Motor Mounts???-s-l1600-1-.jpg
Old Feb 22, 2018 | 01:20 AM
GageD1's Avatar
GageD1
Exclamation
If you have the time here's the link to a ram transmission mount for a 2500 if that made a difference but I planned on doing similar like in this video
Old Feb 22, 2018 | 03:20 AM
MoparFanatic21
https://www.youtube.com/watch?v=UkcZq_pH0ck
That should work as the 2500 and 1500 share the same frames and mounts
