Can someone explain to me how to Replace my Motor Mounts???
Old Feb 22, 2018 | 08:10 PM
  #31
GageD1's Avatar
GageD1
Lightbulb
Originally Posted by Ramman18
Those look different than what we have. I know mine matched the diagram you first posted. Just re-use the old ones! Simple = no headache.
I think I might end up going your route I'm gonna see if I can check and see by open the hood and looking to see if I can reuse them, because I am at work so I am not able to check right now were your original ones that matched the diagram metal like?
Old Feb 22, 2018 | 08:17 PM
  #32
GageD1's Avatar
GageD1
Exclamation
Probably have to look from under the truck, and even then, I hope you have a flexible neck.
When I get off my shift Ill take a pic to verify with you guys to see if I'm looking at the right stuff. Hopefully I do lol
Old Feb 22, 2018 | 10:36 PM
  #33
GageD1's Avatar
GageD1
So just to show we're all on the same page here's what I was looking at...
Left Side
Zoomed in more
Motor mount??? Above it the shield?
Old Feb 22, 2018 | 10:40 PM
  #34
GageD1's Avatar
GageD1
Also I've tried posting a picture in my ablum in its still locked... lol
Old Feb 22, 2018 | 10:54 PM
  #35
Well, I'm seeing some pics at least....... are you hosting those elsewhere?
No clue on why you can't post pics, we are still waiting for an admin response. (don't hold your breath......)
Yep, that's the motor mount below the heat shield. Two pieces, one bolts to the frame, (or, might be riveted) the other bolts to the engine block. If you pull them off the block, check the freeze plugs behind 'em. They LOVE to rust out.
Old Feb 22, 2018 | 11:31 PM
  #36
GageD1's Avatar
GageD1
Cool
Yea most of them I posted prior to that issue, but im choking over here lol! and sweet stuff right the there! so the "restriction pads are inside of those cylinders huh? and I will look in those freeze plugs too in the mean time!
Old Feb 23, 2018 | 12:16 AM
  #37
GageD1's Avatar
GageD1
Exclamation
A link to a freezer plug removal and installation example
Now what confuses me is I believe this goes along with your coolant system, so he had said once you replace them to do a coolant engine flush. Now so once I replace the motor mount and freezer plug, do I just flush the radiator and stuff with water then add coolant back to the system? Whats your thoughts??
Old Feb 23, 2018 | 12:36 AM
  #38
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by GageD1
A link to a freezer plug removal and installation example https://www.youtube.com/watch?v=U3oiVy_CZus
What he means by "coolant engine flush" is run water through your engine or a cleaner through there to clean the coolant passages
Old Feb 23, 2018 | 12:54 AM
  #39
GageD1's Avatar
GageD1
Exclamation
So let's say I take the freezer caps off, will all of the coolant rush on out???
Old Feb 23, 2018 | 08:51 AM
  #40
Yes, it will. Drain as much of the system as you can before you remove them, otherwise, you get a shower.
