Oil Pressure, but no Oil pressure gauge.
Old Apr 4, 2018 | 08:34 PM
MoPartsPlz's Avatar
MoPartsPlz
Default Oil Pressure, but no Oil pressure gauge.
Hello I have a 99 Dodge ram 1500 Mag.v8 Just swapped out the motor with a re-manufactured motor, at first the temp. would shoot to H, but the motor was not hot (had oil pressure gauge read normal then) swapped sensors and gauge was normal but now no oil pressure gauge,swapped 2 oil pressure sensors checked pressure manually, reads good but no gauge in cluster. Any advice appreciated thank you!
Old Apr 4, 2018 | 10:43 PM
2bit's Avatar
2bit
My best guess is you didn't get all the grounds reattached. That or they need to be cleaned.
Old Apr 5, 2018 | 08:02 PM
MoPartsPlz's Avatar
MoPartsPlz
all grounds clean and in place,swapped out a couple more oil sensors, a working oil sensor from another motor of the same model,changed the cluster dont know what else i can do, getting 5v to the sensor but nothing on the gauge and i cant find a wiring diagram anywhere also the compressor wont kick on, also changed the control panel a real head scratcher
Old Apr 5, 2018 | 08:04 PM
Ignition on, short the pins on the OPS connector together. Does the gauge move? Do all your other gauges work? You can download a service manual from here, wiring diagrams are in section 8W.
Old Apr 5, 2018 | 08:10 PM
MoPartsPlz's Avatar
MoPartsPlz
tried shorting them and it wouldnt budge, not even a wiggle, thank you for the manual link
Old Apr 5, 2018 | 09:32 PM
Time to plug in to the PCM, and see if IT has a clue what oil pressure is.
Old Apr 5, 2018 | 10:34 PM
MoPartsPlz's Avatar
MoPartsPlz
no codes to read on OBD and the automotive diagnostic scanner says oil pressure reads 0, manual gauge says its good
Old Apr 6, 2018 | 08:08 AM
Verify continuity on the signal return wire back to the pcm for the oil pressure sensor.
