Wild vent workaround
Old Jul 15, 2018 | 06:19 PM
  #31
weazel's Avatar
weazel
No, I got the Dorman 47170. (well 2 of them actually) The one I replaced looks just like the one pictured above but it is all black plastic. (no clear side) It is the same size and the same shape though. I wasn't aware there was a larger one.
Old Jul 15, 2018 | 10:16 PM
  #32
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The large one is suppose to replace that little one. It's in a TSB to fix the wild vents issue, it has a small reservoir in it to. Dodge installed that one it you complained of that vents issue.
Old Jul 20, 2018 | 04:50 PM
  #33
weazel's Avatar
weazel
Do you by chance have the part number for the larger check valve?
Old Jul 20, 2018 | 07:04 PM
  #34
MoparFanatic21
Yep it's 04677204 and will look like this
Old Jul 21, 2018 | 12:04 PM
  #35
Moparite's Avatar
Moparite
The TSB is for the early rams that only have one check valve. If you have two already it shouldn't make a difference witch one to use other than the larger one may last longer due to the size of the valve in it.
http://dodgeram.info/tsb/1996/24-01-96a.htm
Old Jul 21, 2018 | 02:25 PM
  #36
MoparFanatic21
Interesting I didn't read the whole thing. I know I have two and replaced them and still had the vents issue (01 Ram) and didn't help until I installed the bigger one.
Old Jul 22, 2018 | 10:51 AM
  #37
Moparite's Avatar
Moparite
You have to check to see witch end goes towards the engine, I noticed this with the ones from napa that they have a mark like the oem ones but work backwards. They will not work if not put in correctly.
Old Jul 22, 2018 | 11:29 AM
  #38
MoparFanatic21
I bought Mopar check valves
Old Jul 22, 2018 | 05:51 PM
  #39
ramvan61's Avatar
ramvan61
MoparFanatic21 do you have any fitment issues with the new larger check valve ? I"m just looking for heads up mine should be here next week. Thanks for the help.
Old Jul 22, 2018 | 08:13 PM
  #40
MoparFanatic21
The fittings were a bit larger then what the factory line is. What I did was got the right hose to fit the check valve and surprisingly the factory line fit right into it. I forget the size. But that is the only fitment issues that I had. I will say I only had them switch back to defrost once and that was climbing a steep grade for over an HR. Which is normal as all the vacuum was used up.
