transmission or torque converter?
Old Sep 18, 2018 | 06:47 PM
cman9898's Avatar
cman9898
Default transmission or torque converter?
Hey folks got another issue... this time Ive got a sound coming from the back of the engine that sounds like a metal disk bouncing off something. this noise only starts around ten MPH. It started while I was rnnning some errands, and within about ten miles I got a loss of power until I floored it hen got power back for a few seconds then it would disappear again. I still get power starting then it goes away.
Old Sep 18, 2018 | 08:20 PM
Does the trans start slipping?
Old Sep 18, 2018 | 10:12 PM
cman9898's Avatar
cman9898
no it doesn't clunk back into gear it just comes back alive
Old Sep 19, 2018 | 08:16 AM
Not sure I understand.... That sounds more like an engine problem than a trans problem.
Old Sep 19, 2018 | 09:38 AM
cman9898's Avatar
cman9898
if it is in the engine then what could I be looking at? the motor has less than 100k on it... could it be from water intake? I was in the middle of Florence for a bit.
Old Sep 19, 2018 | 11:00 AM
Was the problem present before Florence? If not, something may indeed have gotten wet. But, running down the freeway for awhile should dry everything out. (gets toasty warm under the hood.....)
Old Sep 19, 2018 | 12:55 PM
cman9898's Avatar
cman9898
that's the odd part it doesn't occur at low speed but when I hit 45 it looses all power
Old Sep 19, 2018 | 12:56 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do you have a check engine light?
Old Sep 19, 2018 | 01:24 PM
cman9898's Avatar
cman9898
yes and when it got read a couple weeks ago it said it was a evap canister
Old Sep 19, 2018 | 03:53 PM
MoparFanatic21
There is a chance that it could be your engine and not your transmission. Any shaking?
