Heater
Old Oct 2, 2018 | 08:42 AM
  #21
Air pocket in the heater core.
Old Oct 2, 2018 | 08:49 AM
  #22
Tamuiel's Avatar
Tamuiel
if its air i cant get it out! Thanks 4 reply
Old Oct 2, 2018 | 08:51 AM
  #23
Yeah, it can be a pain to get it all out. Trouble is, the heater core outlet is the highest point in the cooling system. Installing a bleed there would probably work really well. Just a pain to get to. (and almost impossible on the 8.0.... its CROWDED back there.
Old Oct 2, 2018 | 09:10 AM
  #24
Tamuiel's Avatar
Tamuiel
thanks. Mine is the 5.9 . do u know the size T to get? Home depot? Clear hose and valve?
Old Oct 2, 2018 | 03:17 PM
  #25
Just get a flush kit, it will come with a couple different T's, with caps. Install the correct one, start the engine, let it run at idle, and loosen the cap. Let it flow until no more air comes out, tighten the cap. (really should take more than a few seconds.....) Do NOT take the cap OFF, just loosen it up enough so it is no longer sealed. (can make a BIG mess in a hurry.)
Old Oct 2, 2018 | 03:27 PM
  #26
Tamuiel's Avatar
Tamuiel
ok, thanks. We do the ac and heat work on the building at the local dodge dealer. Just talked to a tech and he said air was pretty common on the 2nd gen
Old Oct 2, 2018 | 03:30 PM
  #27
Yup. That's why we see so many threads about it.
Old Oct 2, 2018 | 03:52 PM
  #28
Tamuiel's Avatar
Tamuiel
thanks brotha
  #29
Let us know how it turns out.
Old Oct 2, 2018 | 04:09 PM
  #30
Tamuiel's Avatar
Tamuiel
Will do
