1st time builder
Old Nov 12, 2018 | 01:34 PM
  #51
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by I WILL RULE YOU!
Well didn't get much done to the Dodge. Did get the brakes done on the Avalanche and decided to check the ujoints on it and ended up replaceing them. Started on the Ram and my impact froze up. Got to aggravated to continue so went in to watch the Dawgs play Auburn instead. I learned a while back to just walk away and not damage anything when I'm in that mood. So now I have to wait a couple of weeks. Going to go ahead and order the steering box though, while Blue top still has it in stock. Anyone have a suggestion on a pump. Mine is still good. Thinking of just cleaning it up and rebuilding it.
I try to rebuild OEM stuff as often as I can (not only do I learn USUALLY save some cash to). I have never replaced any pump on any second gens yet so I can't even begin to give you any information there, and I probably won't I'll just rebuild it lol
Old Nov 12, 2018 | 03:34 PM
  #52
I just got one from the local parts store and installed it. Quick, painless, and easy.
Old Nov 13, 2018 | 05:45 PM
  #53
I WILL RULE YOU!'s Avatar
I WILL RULE YOU!
Well tell y'all what happened the bad - came home from work yesterday to a van in my ditch , driver was ok , and took out my mail box. The good - it was an auto glass installer and not only did his boss give me a hundred fifty bucks, they are going to install a new windshield in ol yeller. Not a bad trade since it has had the infamous 2nd gen Ram crack in it for the last 12 years.
Old Nov 13, 2018 | 07:49 PM
  #54
MoparFanatic21
I was I could find the Ram ceo in my ditch
Old Jan 1, 2019 | 10:26 AM
  #55
I WILL RULE YOU!
Ok haven't got to post in a while. Weather has totally sucked in Mobile AL for the last two months. Everytime I get a chance either the weather sucks or life happens. So I have got to do some research. I found a complete 8 L V10. It is a complete engine with wire harnesses. $800. Would it be worth going that route? Trying to decide on extra costs of rebuilding it, getting a new tranny, and other stuff. Any opinions out there? Well HAPPY NEW YEARS TO ALL!!!!
Old Jan 2, 2019 | 10:04 AM
  #56
What truck are you wanting to put it in, and what's in there now?
Old Jan 2, 2019 | 01:29 PM
  #57
I WILL RULE YOU!
The 99 Ram 1500 sport. It's rear wheel drive, regular cab with a 5.2 magnum. I'm still working on replace everything in the frontend and converting to rear disc brakes. Just haven't decided on what I am going to do as far as a motor yet. A 408 build is what I am leaning towards. But open to just about anything until I get thru with the brakes and suspension.
Old Jan 2, 2019 | 01:34 PM
  #58
I think the 408 would be easier.... but, probably get about the same gas mileage. Dropping the V-10 in there would be a nice power boost, but, you would need the trans as well.
