No heat!!!!
Old Nov 23, 2018 | 11:42 AM
  #21
wrnchbndr's Avatar
wrnchbndr
Just with continued use, my heat is getting better.
Old Nov 23, 2018 | 07:52 PM
  #22
adukart's Avatar
adukart
Yeah, I need to address this too. My heater is extremely anemic........ barely blows hit on the middle fan speed. I am sure it's just an air pocket in the core, but, with the v-10, getting to the hoses back there is problematic, at best...... May have to get creative.
I am going to try cutting the hose close to the outlet of the heater core, install a flush T, and use that to bleed the air out of the core. I am 'hoping' that will solve the issue.
I had this issue as well, you need to make sure you have a higher quality thermostat in it and a good cap. Otherwise some coolant is allowed to by pass the core all the time.\\
This is the good style (notice the seal on the cylinder that moves, the cheap ones don't have that and coolant flows out there):
Old Nov 23, 2018 | 09:31 PM
  #23
Yup, that was the first thing I did. Turns out, I should have scanned the truck first.... I was used to the temp gauge in my 96, and on my 98, it reads different, but, the engine WAS getting up to temp, and staying there...... So, I spent money I didn't have to. I got a Stant stat, and replace the stat, and the seal at the bottom.
