Question..Muffler delete backfires.. possible way to eliminate?
Old Nov 20, 2018 | 06:32 PM
AceC's Avatar
AceC
Default Question..Muffler delete backfires.. possible way to eliminate?
Hey everyone. Always read the forums just finally joined. I hope this is in the right section. I have a 98 ram with a 318 manual. I cut my muffler off and was wondering if there was a way to stop the backfiring. I had the battery disconnected when i took it off and it only really does it when its warmed. Once its warm it does one as i shift then its like a machine gun letting off the throttle in gear. If i give it just a little gas while engine braking it stops. Any advice is appreciated
Old Nov 20, 2018 | 06:35 PM
I don't think it should do that....... How old is your O2 sensor?
Welcome to DF!
Old Nov 20, 2018 | 06:45 PM
AceC's Avatar
AceC
The downstream is maby 2 years old and upstream is factory
thanks for the quick reply
Old Nov 20, 2018 | 06:46 PM
Unplugging the front sensor would probably just make the problem worse..... Last time you did a tune up?
Old Nov 20, 2018 | 06:53 PM
AceC's Avatar
AceC
I just did plugs wires distributer rotor and cap and new air filter at the beginning of summer
Old Nov 20, 2018 | 07:01 PM
So that shouldn't be a problem..... If the front O2 is original, replace it. NTK or Denso sensors only please. These trucks don't like Bosch.
Old Nov 20, 2018 | 07:06 PM
AceC's Avatar
AceC
Ill give that a try when i get a chance. Thank you for the advise.
Old Nov 20, 2018 | 07:08 PM
Let us know if it works.
Old Nov 20, 2018 | 07:53 PM
AceC's Avatar
AceC
Will do
Old Nov 20, 2018 | 09:01 PM
Shadow_Death's Avatar
Shadow_Death
BWAHAHAHAHAAH! Man..... You mean like this?
This is just a difference in air pressure between the outside of the exhaust and the inside. My 96 is dumped after the Thrush Turbo, because I was too lazy to extend it out, and if I WOT it down the highway and let off mine will make a loud bang. Glass packs were/are notorious for popping when you decelerate while in gear. It's the same principal.
