Updates?
Updates?
For this one: https://dodgeforum.com/forum/2nd-gen...ock-hatch.html
I can lift the door slightly but something I noticed was that I can lock the door then close it and it latches but still won't lock.Otherwise it has trouble even latching. Should I just replace pins and actuator/lock mechanism?
And this: https://dodgeforum.com/forum/2nd-gen...-sounds-2.html
It really just does the noise if its been sitting and usually goes away after warmup and a drive but I'll still have it looked at.
And I also had the common oil pressure drop and was told to replace the pressure sensor and pump but is there any specific brand for either I should look into?
