46re whine in gear only
Old Feb 3, 2019 | 11:58 AM
24vtd's Avatar
24vtd
Default 46re whine in gear only
Im having some trouble with my transmission. Rebuilt it about 600 miles ago and everything went great. Started whining in all gears but not park or neutral. No slipping at all and shifts great. It sounds like the torque converter is making the noise. Is there a way to check pressure on t/c pressure or for bad bearings in it? Its a patco 1800 stall.
Old Feb 3, 2019 | 12:57 PM
You can check pressures if you have a gauge, there are test ports on the trans in various places. No way to check the internals of the t/c though, at least, not without cutting it open, which I really do not recommend.
Too many things can make it whine though. Low fluid, an internal leak, bands too tight, etc.
Old Feb 3, 2019 | 01:46 PM
24vtd's Avatar
24vtd
I will pull the pan first and recheck band. It worked fine up until this morning.
Old Feb 3, 2019 | 09:14 PM
24vtd's Avatar
24vtd
Found the problem. after we checked pressure adjusted bands and slopped tranny fluid on the floor, found it to be the junk patc converter. awesome get to remove transmission again. Gonna call them tomorrow and see what they will do about the tc.
Old Feb 3, 2019 | 10:19 PM
Did it scatter debris thru the rest of the trans? If it blew up internally, highly likely it did.....
Old Feb 3, 2019 | 10:22 PM
24vtd's Avatar
24vtd
No thank goodness. I parked it as soon as it started doing it. the pan was still clean.
Old Feb 3, 2019 | 10:23 PM
24vtd's Avatar
24vtd
where do you get a good tq?
Old Feb 3, 2019 | 10:27 PM
Talk to PATC. They usually are pretty reliable.....
Old Feb 3, 2019 | 10:39 PM
24vtd's Avatar
24vtd
thats whats in it now.
Old Feb 4, 2019 | 09:13 AM
And it should have a warranty. Do you really want to buy another one, from someone else?
