Abs and brake light
You always beat me to it
The whole story goes like this, I bought the truck last may and a couple days after buying it the abs would chatter, do its thing I guess and the lights would come on. After a few days, or weeks of driving, eventually the light came on instantly and the abs quit working. I then replaced the rear differential sensor and the sensor on the driver side of tranny. Neither helped. Now every now and again the speedometer quits working. Shut it off and restart and it's fine for a few days. I dont know if one has something to do with the other or not.
sorry for the long read
Trending Topics
Can you elaborate a little more on "the abs would chatter" ? Did it appear to kick in without applying the brakes ? Or did it kick in while normal braking on dry road ? My truck is similar, same year and drivetrain but a 2500. On this truck with 4 wheel ABS (I think in 2001 there was no rear wheel only ABS any longer) the speedo is not fed from the rear axle sensor. When I got the truck it had the ABS and brake warning lights on as well. The rear axle sensor tested open but the speedo worked. I *believe* (have not found confirmation) that the speedo is fed by one or both of the front wheel ABS sensors. It can't be from the transmission because the speedo would be off in low range, and there is no sensor at the back of the transfer case. So check the front ABS sensors.
DerTruck, the abs would chatter as I applied the brakes on dry pavement. You get mixed stories as to what the speedo works off. Had a mechanic say it's the sensor on the tranny and another say the rear axle sensor. I'll look into the front sensors this weekend. Thanks for the input and I will keep you posted.
That would indicate a sensor reading being interpreted as the wheel slowing down more than expected. From what I gathered there are differences between the earlier and later models, I guess when the instrument panel changed. Earlier models have a speed sensor at the transfer case and presumably drive the speedo from there. Later models use a signal from the ABS controller. Good luck !
