96 ram 1500 window help
Old Feb 15, 2019 | 10:37 PM
96ram150's Avatar
96ram150
Default 96 ram 1500 window help
I just bought a 96 ram 1500 key was lost but the driver window is down. Is there a way I can remove the driver window switch and use jumper wires from the battery to the wires on switch connector to basically bypass the switch and roll up window? If so witch wires need to be grounded and powered with 12volts?
Old Feb 15, 2019 | 11:41 PM
ranger140892's Avatar
ranger140892
Yes. Just pull the door panel and unplug the connector. You can jump with hot and neg wires to the connector. I just did it a few days ago while replacing window regulator and motor.
Old Feb 16, 2019 | 12:08 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can also unplug the door connector under the dash and jump it there
Old Feb 16, 2019 | 03:08 AM
HeikIlm's Avatar
HeikIlm
Or remove the fuse from the dash fuse panel, and either jump it there from hot fuse, or from the battery.
Old Feb 16, 2019 | 07:56 AM
There won't be any power at any of the connectors unless you supply it from somewhere else.
Old Feb 16, 2019 | 08:04 AM
HeikIlm's Avatar
HeikIlm
Yes, there is. Lowest row of fuses, I.O.D, park lamps, power locks and stop lamp all have power when key is off.
Old Feb 16, 2019 | 08:07 AM
I was referring to the various connectors for the windows. Window circuit doesn't get power with the key off. Sure, you can find power in a variety of places, and supply from there. Just need to get the right spot.
OP can download service manual from here. Wiring diagrams are in section 8W. I think pulling the door panel would be easiest..... the connectors at the body are a pain to get to.... supply power and ground to the window motor, and see what happens. If it doesn't go the right way, reverse the wires.
Either that, or if you have a title in hand, take a trip to the dealership, and have them cut a key. Gonna need one anyway.
Old Feb 16, 2019 | 09:11 AM
96ram150's Avatar
96ram150
Thanks for the info guys but I went ahead and bought a new ignition lock cylinder with keys. Now new question how can I remove the old lock cylinder without a key
Old Feb 19, 2019 | 04:05 PM
HeikIlm's Avatar
HeikIlm
Ah, yes. I was jumping into conclusions before my brain interpret what I was reading. Sorry bout that.
Anyway, if OP still has windows down, or someone finds this thread, here's how one can operate windows without keys: pull the fuse panel cover, and window fuse from upper right corner and 20A fuse from down row (or any of them).
Then take two pieces of wire and four crimp connectors, and make them like this:
I didn't have narrow blades so I trimmed one down.
Then mount the connector to the frontmost fuse receptacle, this goes to window switch. And the narrow one goes to hot side of the lower row, which is the lower receptacle. Like this:
Or one can be complete hack and just jams piece of wire to the receptacles
