Plenum gasket question...
Old Feb 27, 2019 | 11:04 AM
  #21
Matthewsteven89's Avatar
Matthewsteven89
I need to, but I'm scared too. Lmao. Yall done scared me with the "may be rings/could be worse" problems. 😂😂😂
Old Feb 27, 2019 | 11:07 AM
  #22
Look at it this way, WORST case is going to be rebuild, or new engine.
Old Feb 27, 2019 | 11:21 AM
  #23
Matthewsteven89
Im not mentally ready for that information yet. Hahaha 😂😂😂
Old Feb 27, 2019 | 08:05 PM
  #24
Matthewsteven89
What's the psi supposed to be on compression?
Old Feb 27, 2019 | 10:48 PM
  #25
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
100 is the minimum but I'm pretty sure around 130 is considered good
Old Feb 27, 2019 | 10:54 PM
  #26
Matthewsteven89
So would all 8 pumping out 120psi be considered good?
Old Feb 27, 2019 | 11:04 PM
  #27
MoparFanatic21
For the mileage yeah you just don't want to be closer to 100 so if one was 115 I would look at doing a rebuild
Old Feb 27, 2019 | 11:10 PM
  #28
Matthewsteven89
Im not sure how much it would matter but this was a cold test, truck hasnt been started since this past weekend...
Old Feb 27, 2019 | 11:20 PM
  #29
2bit's Avatar
2bit
The main thing is that they are all similar. What you have is good. Change the plenum and tune it up. It'll run good for a long time yet. I still recommend a timing chain while your that far a part.
Old Feb 27, 2019 | 11:25 PM
  #30
Matthewsteven89
Definitely needs a tune up!!!!!! I did notice when pulling the plugs they were all excessively gapped... way more than the .035... so it definitely needs plugs and wires. And I'll throw a cap and rotor on while I'm at it too. Maybe this will get the ol girl by until I get the means and funding to rebuild or replace the engine. Thanks guys
