1996 ram 1500 5spd transmission
I just cracked my bellhousing on my transmission and cant afford to get a brand new one. What other dodge trucks can I use the transmission out of? Its a 1996 1500 4x4 5spd manual with a 318. If anyone has a link to a chart or knows off hand any help would be greatly appreciated.
According to Wikipedia the NV3500 was used in these applications within your year range.
1994 - 2001 Dodge Ram 1500
1994 - 2004 Dodge Dakota
I would look for it in a 1996 Ram 1500 or a 1996 Dodge Dakota just to be sure all the sensor plugs are the same so you won't need to do any rewire or extra work when swapping them around.
It did say that it's also available in 1994 - 1995 Dodge Ram 2500 Light Duty but I don't know if it used all the same sensors or if they added any extras in 1996 when they switched to OBDII.
Actually, it's a two piece housing with integrated bell housing. And GM used it also from 1988-2006 but called it the Getrag 290. Dodge continued it until 05 in the 1500s behind the Magnum 3.7 and 4.7.
Trending Topics
Ive just got one shot on doing this. So I have to make sure i get the right one. Im thinking if I go to pullapart and get the Chevy 5 speed and a dodge bellhousing i should be good. At least from what I'm gathering from research and y'all.
