2 trucks into 1 truck
Old 04-14-2019, 12:46 PM
Bonnevillej's Avatar
Bonnevillej
Bonnevillej is offline
Default 2 trucks into 1 truck
I have 96’ and 00’ ram 1500. I want to make one truck out of both. The 00’ has a bad frame and the 96’ has a bad cab along with the transmission and transfer case. My buddy is trying to tell me to just replace the transmission and transfer case and fix what’s wrong with the cab. Where as I want to replace the cab, motor, transmission and transfer case due to the fact having a hard time getting the motor to start in the 96’ and and a lot of the wiring is missing. So long story short witch would be the best way to go?
Old 04-14-2019, 05:06 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,192 Likes on 2,945 Posts
A LOT changed from 96 to 2000..... So, swapping the cab, motor, trans, and t-case is about the only option, if you want things to actually work.
Old 04-14-2019, 05:55 PM
Bonnevillej
Thanks for the input figured that would be the best way to go considering that everything works on the 2000
Old 04-14-2019, 06:08 PM
Bonnevillej
Do you know of any tips or tricks I can do to help make the process go smother and faster?
Old 04-14-2019, 06:47 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Label everything and take pics. I would pull the bodies on both and then transfer the whole drivetrain then put the body on
Old 04-14-2019, 08:28 PM
HeyYou is offline
This.
Gonna be a lot of work, but, you will like it in the end.
Old 04-14-2019, 10:34 PM
MoparFanatic21
This.
I personally would love to do that!
Quick Reply: 2 trucks into 1 truck
