Rebuilt Transmission
Old Aug 17, 2019 | 01:27 PM
Juan Sauceda's Avatar
Juan Sauceda
Default Rebuilt Transmission
1996 Dodge Ram 5.9 I rebuilt the transmission and these are the codes it gave me. Help
Old Aug 17, 2019 | 03:50 PM
Did you replace the electronics?
Old Aug 17, 2019 | 04:34 PM
Juan Sauceda
Yes, I replaced the electronics as well. I’m gonna put the old wiring harness and hopefully that’ll be the issue.
i think I found the Issue.
I have a 1997 ECM instead of the original 1996 ECM. Will that be the determining factor?
Old Aug 17, 2019 | 06:00 PM
96 and 97 should be pretty much the same thing. I don't *think* any of the pinouts changed..... but, I haven't looked at every single one of them either..... Pinout on the trans connector did not change though. (but, wire colors may have.....)
Old Aug 17, 2019 | 08:37 PM
Juan Sauceda
I confirmed that the ECM is the right one on. I changed the electronics inside the transmission as well. Still have the same codes.
Old Aug 17, 2019 | 08:47 PM
Fix the first one, it will take care of the second one. Pressure sensor is only supposed to get 5 volts, my guess is, it's getting 12. Got a short somewhere.
Old Aug 17, 2019 | 09:14 PM
Juan Sauceda
Thank you. I’ll update as soon as I find that shortage.
Old Oct 7, 2019 | 08:23 PM
Juan Sauceda
Well I changed the connector plugs and bought a remanufactured PCM. Is there still a short somewhere?
Old Oct 7, 2019 | 08:37 PM
Is there? Is it still doing the same thing?
Old Oct 7, 2019 | 08:42 PM
Juan Sauceda
Yes it’s doing the same thing.
