Fuel pressure reading off top of filter housing
Old Aug 24, 2019 | 05:42 PM
Neil Napper's Avatar
Neil Napper
Default Fuel pressure reading off top of filter housing
Hi everyone I installed the edge EAS pressure sensor on the banjo bolt on top of the fuel filter housing. With a new filter I’m seeing 9 psi at an idle. 7-8 under empty acceleration. Seems low to me any other thoughts? Also this is a 1999 with the original filter housing with taps in the top.
Old Aug 24, 2019 | 06:42 PM
Diesel? Is that pressure from the lift pump?
Old Aug 24, 2019 | 06:54 PM
Neil Napper
Yes it’s diesel. This is the pressure reading from the lift pump using the edge transducer with the eas kit. Leaving in two days for a 1000 mile trip and I don’t like the readings I’m getting. Hoping for a solution I can install with in stock (tomorrow being Sunday) parts from autozone or advanced auto.
Old Aug 25, 2019 | 09:49 AM
Yeah, that's WAY low..... should be around 25 PSI or so. Time for a new lift pump??
Old Aug 25, 2019 | 05:22 PM
HeikIlm's Avatar
HeikIlm
Actually, it's not that low. VP44 requires 5-7 psi while cranking, and minimum of 10 psi at idle speed.
Old Aug 25, 2019 | 05:29 PM
Service manual I looked at disagreed..... or, I didn't read far enough.....
Old Aug 25, 2019 | 07:28 PM
HeikIlm's Avatar
HeikIlm
Me too, first 98-99 manual, but only found P7100 specs (which was used in early 98, until 98.5 they switched to a VP44), so I went to a 00-01 manual which had VP44 specs.
Old Aug 26, 2019 | 10:09 PM
ranjanty's Avatar
ranjanty
I use a regular pressure gauge on top of my fuel filter and mine reads 22. Do you have the stock lift pump? or a after market?
