Torque Converter Staying Locked and No Power in Overdrive
Old Sep 24, 2019 | 06:23 PM
  #21
It's possible...... No clue how to test that though.
Old Sep 24, 2019 | 06:28 PM
  #22
Brokendodge96's Avatar
Brokendodge96
I'll do some research and maybe some experimenting with it. Hopefully something fixes it
Old Sep 24, 2019 | 09:10 PM
  #23
Brokendodge96
Another update, went to go for a drive today to the shop (to have synchro done) and she quit on me twice so had to head home. Messed around with the distributor a little to see if I could get any closer to center and turning it equally either way killed it. Definitely having that done sooner rather than later. Typically TCC are changed during trains rebuilds, although I was wondering if that could also be a part of the problem. I checked the CEL flash codes when I got back as well which came up with an 11 and 21 which are crank and 02 related. The crank is most likely when tried to start it and it didn't want to (which has happened before). And the 21 is what I assume to be the same downstream 02 sensor that I put the non fouler on. I was ticked enough that I ALMOST traded it for a Ford today.
Old Sep 25, 2019 | 07:32 AM
  #24
Crank sensor would definitely make it stop running. If you decide to replace it, be sure and get a genuine mopar sensor. These trucks don't really care for the aftermarket fellers.
Old Sep 25, 2019 | 07:38 AM
  #25
Brokendodge96
I replace it about a month ago but maybe I'll order a genuine one
Old Sep 28, 2019 | 04:28 PM
  #26
Brokendodge96
Update:
As I was messing around with the crank sensor bolts I noticed that every time I wiggled the wires the fuel pump would turn on (the key was in the on position but not running obviously). At first I thought it was a fluke but it became apparent that something wasn't right. Anyways, I put the old one back in and voila she's been running not half bad ever since. It has some cracks in the wire so I ordered one from the dealer as well. However my overdrive still doesn't have any power and I am still stuck as to why that is. On the plus side, my cruise control started working for some reason and although I've heard that the overdrive may work well while in cruise sadly mine did not change so back to the drawing board
Old Oct 10, 2019 | 07:43 PM
  #27
Brokendodge96
Went to the dealer to ask for the schematic. They said that this was the best they had and I haven't been able to find much else on the google in relation to overdrive. Might help someone else out if they need it too.
Old Apr 7, 2020 | 05:22 PM
  #28
Brokendodge96
Smile
About a month ago I went on a whim from a shop and threw in a new valve body. Turns out the one that was put in during the rebuild was defective internally (check ball or something). Fooled many shops because the sensors were all doing what they were supposed to so nothing red flagged or set an codes. Worked perfectly until I probably pushed it a little too hard in the swamp and now it starts in second unless I put it in first manually. Regardless though, it turned out the initial problem was the VB. I appreciate all those who took time to help out along the way! :thumbsup:
Old Apr 7, 2020 | 10:30 PM
  #29
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The non fouler trick did you do it on the O2 sensor or the spark plugs?
Old Apr 8, 2020 | 07:42 AM
  #30
Brokendodge96
I did it on the 02 sensor and still working like a charm, no more CEL
