ABS Code 2
ABS Code 2
Ok so I have been fighting with this code on my 96 Ram 1500 RWAL. The code is #2 so I went to the FSM to diagnose it. Well the circuit from CAB Connector #1 to the RWAL is good. I don't know how to "check resistance of isolation valve" as the FSM says. I know my CAB is good as I tested it in my 97 which has a bad CAB.
Does that mean my RWAL Valve is bad even though it isn't listed as a culprit? Here are the pages from the FSM.
Can anyone help? I hate the lights being on.
From 8W-34-1: "Circuit B108 from cavity 8 of the CAB feeds the dump solenoid. The isolation solenoid is powered on circuit B101 from cavity 1 of the CAB. Circuit Z8 provides ground for both solenoids." So with an ohm meter measure the resistance between pins A and B on the 4 wire plug. 3-6 Ohms is pretty small so use a good meter.
Ground tested good, even though the Valve is case ground
Trending Topics
