1998 1500 5.9 p1762
1998 1500 5.9 p1762
First time poster, and first time dodge owner. Back in April I bought this old 98 ram 148k on the ticker.
driving home from work the other day coasting down a hill getting ready to make a sharp turn and as I navigated through the corner and got on the gas it acted like it found neutral. Gulp. Let off and eased back into it and it hooked up and drove/shifted fine. Check engine came on shorty thereafter. Pulled the code and it’s a P1762. Oh no!
So I’ve done a little reading about this, and think I have the capabilities to repair if it’s the gov sensor. I’ll replace the O2 sensors anyway since they’re old and crusty and likely the originals.
So my question. What is the correct part number(s) for this repair? Looking on Rockauto and there’s a handful of different sensors and pressure related components. Just trying to be sure I’m getting the right stuff.
Thanks!
Thanks!
You should have the 46RE trans. Get the borg warner heavy duty governor pressure sensor/solenoid set. (can get the output speed sensor as well, if you are feelin' froggy.) While you are in there, change the fluid/filter, and adjust the bands. If you don't find anything odd in the pan when you drop it, that *should* take care of the issue.
Just want to get this right.
Thanks!
Thanks again, you’ve been a big help.
New codes! P1764 P0138
So, I swapped the governor and transducer, 3-4 accumulator spring(old broken) speed sensor on trans, and rear abs sensor. I probably should have went a step farther and dropped the VB and replaced the overdrive and lockup solenoid. But I didn’t. lol.
7 quarts of atf+4 later. Fired her up and CEL popped back on while warming up. Pulled the codes and now it’s a 1764 and 0138. Cleared the codes and drove around for a little while and nothing back on yet. Still waiting on O2 sensors to arrive to swap those out.
0138 is rear downstream sensor Rich correct? How do I not have an upstream sensor showing rich? Regardless I’ll be swapping those when parts arrive. Loads of fun.
Trending Topics
Just an update. O2 sensors arrived. Swapped out both at the same time. Went for a couple short drives around the house over the weekend.
To work this morning(27 miles one way) and so far no codes and things are working like they should. I’ll keep my fingers crossed and hope that was in fact the issue. Otherwise seems to be operating normal.
