Fuel line quick connect
Old Dec 18, 2019 | 10:06 AM
Tim Horan's Avatar
Tim Horan
Default Fuel line quick connect
I was dropping my gas tank and found that the quick connect that attaches to the pressure regulator was cracked so I need a new quick connect there and don't want to buy the whole line. What size quick connect do I need? I measured the od of the regulators outlet and it it's size it just about 3/8. I picked up a 3/8 quick connect and it didn't fit. Too small.
Old Dec 18, 2019 | 10:10 AM
Too small, or just a lot tighter fit than the old one? I do believe they are indeed 3/8ths. Might try a bit of grease on the male part of the fitting, to help it go on.
Old Dec 18, 2019 | 10:34 AM
Tim Horan's Avatar
Tim Horan
It definitely didn't fit in general. The white piece that clicks into the quick connect to hold it on wouldn't even slide into the regulator. But I'll try it again before I return it. Maybe I was being too gentle. But I don't think the connection was long enough because even without the click collar it didn't go on far enough
Old Dec 18, 2019 | 01:04 PM
Tim Horan's Avatar
Tim Horan
This is the part I bought https://www.oreillyauto.com/detail/b...=Dorman+5%2F16
Old Dec 18, 2019 | 03:39 PM
ol' grouch's Avatar
ol' grouch
When I put a fuel pump in my Impala, the plastic was rather iffy. Dorman makes an assortment kit so there are several sizes you can try. Too bad your pump isn't as easy as the Impala. 7 nuts holding a plate in the trunk area down and then you're at the pump.
Old Dec 18, 2019 | 06:10 PM
Spillage's Avatar
Spillage
... 7 nuts holding a plate in the trunk area down and then you're at the pump.
6 bolts on the bed and then you’re at the pump ;-)
Old Dec 18, 2019 | 08:12 PM
ol' grouch's Avatar
ol' grouch
The Impala plate weighs around 3 ounces. How much for the bed?
Old Dec 18, 2019 | 08:39 PM
Tim Horan's Avatar
Tim Horan
Ok so I looked at it again and what I'm seeing is that the outlet on the fuel pump is 3/8 outer diameter. This 3/8 connector doesn't fit and feels like it's designed for 3/8 id tubing.
Spillage's Avatar
Spillage
So you need 4 hands, not 1...
But you’re right, working on an Impala (for many/most tasks) is easier.
Old Dec 19, 2019 | 08:37 PM
Tim Horan's Avatar
Tim Horan
Ok so I figured it out. Orielys ****ed up. The put a 5/16 connection in a 3/8 box. I ended up going with an angled 3/8 connection part number 800-086 dorman
