V10 Coil Pack Specs
Old Mar 3, 2020 | 08:44 PM
racefan41's Avatar
racefan41
That sounds like worn valve guides.... You won't necessarily see any smoke from them. These engines burn really clean, and the cat also cleans things up a bit. My old 360 would suck down a quart of oil every 150 miles...... which you would expect would make the truck look like a mosquito fogger.... But, it didn't...... only time I got smoke was at large throttle openings.
Would leak down test be the easiest way to find out? Hard to tell if it's losing oil that way, cause I just now got all the leaking gaskets fixed lol
Old Mar 3, 2020 | 08:45 PM
Leakdown test won't tell you if valve guides are bad. That requires a physical inspection.
Edit: Of course, the bouncing needle also could be an indication of misfires..... how fast it is bouncing is the way you tell between them.
Old Mar 3, 2020 | 08:52 PM
racefan41's Avatar
racefan41
Damn, and I just had valve covers off. The needle is a blur when it vibrates. The misfire/engine shake seems to not be as bad at times as other times. More-so when engine is warm and been driven a while.
Old Mar 3, 2020 | 09:08 PM
That could be any number of things. I might consider doing a power balance test, with the vacuum gauge hooked up, and see what happens. (disable IAC for the test as well.)
Old Mar 3, 2020 | 09:14 PM
racefan41's Avatar
racefan41
I will try that out, hopefully this weekend, and see what happens. Thanks
Old Mar 3, 2020 | 09:32 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Im rusty on the different things the vacuum gauge can do at idle. I would have to read up with my manuals. I would take HeyYous word on it though he's very knowledgeable
Old Mar 3, 2020 | 09:56 PM
racefan41's Avatar
racefan41
Most of what I've read about the vibrating needle does go along with what you guys are saying. I've found a few places where it states this can be an ignition issue as well. Will hopefully get it figured out soon.
Old Mar 3, 2020 | 10:06 PM
MoparFanatic21
I'll read up and let you know. You do have misfires, correct?
Old Mar 3, 2020 | 10:29 PM
racefan41's Avatar
racefan41
Yep, the engine shake isn't felt bad in the truck, but obvious with the hood up and your hand on the engine. The misfires are random and some are stronger than others.
Old Mar 3, 2020 | 10:41 PM
racefan41's Avatar
racefan41
https://actron.com/content/engine-pe...g-vacuum-gauge
Under General Ignition Trouble or Sticking Valves
